17049 Discussions
how to tell Quartus II which serial device (EPCS4) i am going to use to get to Cy II
Cyclone II eval board, i set target device as the fpga, when I open programmer (set to active serial programming) it seems to see board and shows EPCS4 device, but when I read my .pof file it says i have to switch to EPCS16. How is that wrong information getting into .pof file?
never mind, I just found the configuration menu under the device and pin options menu,
Thanks for posting the answer when you found it. It helps other users on the site.
Pete
