integer overflow
Can anyone explain me why ModelSim Intel Starter Edition 10.5b does not complain about integer overflows, i.e. why the following code
process variable n : integer; begin n := 0; report integer'image(n); for i in 1 to 1000 loop n := ((10 * n) + 3); report integer'image(n); end loop; wait; end process;
generates that:
--- Quote Start ---
33
333
3333
33333
333333
3333333
33333333
333333333
-961633963
-1026405035
-1674115755
438711637
92149077
921490773
624973141
1954764117
-1927195307
-2092083883
553997653
1245009237
-434809515
-53127851
-531278507
-1017817771
-1588243115
1297438037
89478485
894784853
357913941
-715827883
1431655765
1431655765
1431655765
--- Quote End ---
- Julien
Interesting - it could possibly be a bug - BUT
It could be that integer implementation in VHDL is tool dependent, and not defined in the VHDL LRM. So you cannot check the range of the 32 bit integer if it goes over 32 bits!
Raise a ticket with mentor and see what they say.
I can see the very same behavior with Vivado Simulator 2016.4.
If it is not defined in the LRM, then I agree it is not really a bug.
Thanks!
- J
