반갑습니다.
운영 PC에 기존 intel. CPU 사용하여 SK하이닉스 SSD 2 개를 이용하여 레이드 사용하고 있습니다에 대한 가상 레이드
문의 내용:
1. SK HYNIX SSD 하나가 OUT 되어 삼성 SSD로 재구성하여 사용하였고 삼성 SSD 만 두고 재부팅시 부팅이 안되는 현상이 있습니다.
2. SK HYNIX SSD 하나를 HARD 복사기를 통해 복사후 복사 된 SSD를 사용시 부팅이 안되는 현상이 있습니다.
문제 해결 방법을 알고 싶습니다.
Hi 영수 하,
It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility from this page, https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html. To run it, please press "Scan". After the scan is finished, click next and there will be a save button, giving you an option to save the logs to a text file, please do so and attach the file on your reply. You can refer to How to get the Intel® System Support Utility Logs on Windows* https://www.intel.com/content/www/us/en/support/articles/000057926/memory-and-storage.html for instructions.
Alfred S
Alfred S
Hi 솔리드,
I wanted to check if you had the chance to read the questions that we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Alfred S
Hi 영수 하,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers.
We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
