i have a problem installing Quartus-web-13.0.1.232 on my win7 64 bit
every time I'm trying to install it I'm getting a msg that "Quartus-web-13.0.1.232 has stopped working" and the options are to debug or stop the process. the install files are good because they work on my xp mode virtual machine. please help !Link Copied
--- Quote Start --- i have a problem installing Quartus-web-13.0.1.232 on my win7 64 bit every time I'm trying to install it I'm getting a msg that "Quartus-web-13.0.1.232 has stopped working" and the options are to debug or stop the process. the install files are good because they work on my xp mode virtual machine. please help ! --- Quote End --- Yes, my machine is a 64-bit one and runs on windows 7 too. I have experienced the same issue and I could use immediate help. What is more interesting is I also installed web edition on XP and it worked quite well.
--- Quote Start --- Yes, my machine is a 64-bit one and runs on windows 7 too. I have experienced the same issue and I could use immediate help. What is more interesting is I also installed web edition on XP and it worked quite well. --- Quote End --- same here : ) on my virtual machine it installed fine try installing it on win7 on safe mode it worked for me.
Thank you :) I did just as you said. It worked. Thanks a lot!
