16920 Discussions
jtagd memory leaks on Ubutnu 20.04
tommmy
When using nios2-terminal to receive output data of nios2 through jtag-uart, the memory continues to increase until the system memory is exhausted.
It seems the jtagd not free the old data received by usb-blaster2
OP system: Ubutnu 20.04
Quartus Prime Pro Version: 20.04
EBERLAZARE_I_Intel
Can you share any screenshot of this output?
tommmy
I do not think any picture can help
just do the same steps like me
use command "top" to see the memory usage, you can find the memory of jtagd continually increase
PR NI VIRT RES SHR %CPU %MEM TIME+ COMMAND
20 0 1029476 993.8m 3696 S 0.3 1.6 68:40.40 jtagd
Jeet14
Let me know if you have any query on this matter.
If no then I will proceed to close this forum case.
Tiwari
