We use Cyclone IV E boards. Under RHEL 7 everything worked fine with USB Blaster / jtagd. Under RHEL 8 the jtagd in the latest version (20.1) never works whereas the jtagd in an older version (15.0.1.150) fails in the same way ( board is seen by quartus but communication to it silently fails until it times out) until the device is unplugged from USB and plugged back in.
-- Joel
Hi, do you see any error message for that? Is the USB Blaster able to be detected?
