I made a .mif file to initialize my ram, but I can not figure out how to specify in the software that the .mif file should be linked to that ram. Any help is greatly appreciated.
Thanks, DustinLink Copied
When you instantiate your ram block you should have passed over initialisation file name then just navigate to your file.
Alternatively edit your ram generics, there is a line for initialisation file.- Mark as New
Ahh thanks, from your post I figured out how to use the megafunction to specify ram. I had made the vhd myself previously. I figured it out now.
