17252 Discussions
modelsim Altera support for vpi and dpi
XXiao2
I am trying to use DPI feature and started with one simple DPI project. I can compile the code (.sv and .c) successfully but when i want to simulated the design. I got the error message:
# Model Technology ModelSim - Intel FPGA Edition vlog 2019.2 Compiler 2019.04 Apr 17 2019
# Start time: 13:31:03 on Apr 09,2020
# vlog -reportprogress 300 -sv -dpiheader cimports.h simple_calls.sv cimports.c
# -- Compiling module top
# Top level modules:
#   top
# -- Compiling DPI/PLI C file cimports.c
# End time: 13:31:03 on Apr 09,2020, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# vsim -dpicpppath /opt/tools/Altera/19.4/modelsim_ase/gcc-4.7.4-linux/bin -c top
# ** Error (suppressible): (vsim-7077) The path '/opt/tools/Altera/19.4/modelsim_ase/gcc-4.7.4-linux/bin' via -dpicpppath switch is not a valid gcc/g++ full path and is ignored.
# Loading /tmp/fxiao@fxiao-Precision-T7600_dpi_18315/linuxpe_gcc-5.4.0/export_tramp.so
# Loading sv_std.std
# Loading work.top
# Compiling /tmp/fxiao@fxiao-Precision-T7600_dpi_18315/linuxpe_gcc-4.7.4/exportwrapper.c
# ** Fatal: ** Fatal: (vsim-3828) Could not link 'vsim_auto_compile.so': cmd = '/opt/tools/Altera/19.4/modelsim_ase/gcc-4.7.4-linux/bin/gcc -shared -fPIC -m32 -B/usr/lib32 -o "/tmp/fxiao@fxiao-Precision-T7600_dpi_18315/linuxpe_gcc-4.7.4/vsim_auto_compile.so" /home/fxiao/verilog_prj/dpi/simple_calls/work/_dpi/auto_compile@/linuxpe_gcc-4.7.4/*.o "/tmp/fxiao@fxiao-Precision-T7600_dpi_18315/linuxpe_gcc-4.7.4/exportwrapper.o"  -Wl,-Bsymbolic '
# (vsim-50) A call to system(/opt/tools/Altera/19.4/modelsim_ase/gcc-4.7.4-linux/bin/gcc -shared -fPIC -m32 -B/usr/lib32 -o "/tmp/fxiao@fxiao-Precision-T7600_dpi_18315/linuxpe_gcc-4.7.4/vsim_auto_compile.so" /home/fxiao/verilog_prj/dpi/simple_calls/work/_dpi/auto_compile@/linuxpe_gcc-4.7.4/*.o "/tmp/fxiao@fxiao-Precision-T7600_dpi_18315/linuxpe_gcc-4.7.4/exportwrapper.o"  -Wl,-Bsymbolic >'/tmp/questatmp.Wxi800' 2>&1) returned error code '1'.
# The logfile contains the following messages:
# /opt/tools/Altera/19.4/modelsim_ase/gcc-4.7.4-linux/bin/../libexec/gcc/i686-pc-linux-gnu/4.7.4/ld: /usr/lib32/crti.o: unrecognized relocation (0x2b) in section `.init'
# /opt/tools/Altera/19.4/modelsim_ase/gcc-4.7.4-linux/bin/../libexec/gcc/i686-pc-linux-gnu/4.7.4/ld: final link failed: Bad value
# collect2: error: ld returned 1 exit status
# No such file or directory. (errno = ENOENT)
# FATAL ERROR while loading design
# Error loading design
# Error: Error loading design
#       Pausing macro execution
# MACRO ./run.do PAUSED at line 29
it seems the library is loaded from a temp folder using different version of gcc:  Loading /tmp/fxiao@fxiao-Precision-T7600_dpi_18315/linuxpe_gcc-5.4.0/export_tramp.so. But compiles the wrapper using gcc comes with the tool which is 4.7.4. How can I specify the library folder? is it an environment variable? I could not find any info about this topic online
SyafieqS
According to link below, the QUARTUS_LIBRARY_PATHS environment variable specifies user-defined library paths. You can use this environment variable to define multiple library paths at the same time, instead of individually adding each path to the user library.
  1. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf (p14-QUARTUS_LIBRARY_PATHS )
  2. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/archives/quartus_install-16.1.pdf (p14-Configuring the Linux User Environment)
XXiao2
Hi there, Thank you for your reply. The tool I am talking about is the modelsim not the Quartus. Can you be more specific about the setting of this environment variable to solve this issue. Frank
