16609 Discussions
modelsim_ae licensing not working
Alexander_M_Intel
Hello, I am an Intel Intern trying to get modelsim altera edition working properly on Ubuntu 16.04. I have the complete Quartus Prime 18.0 Standard Edition and I have Quartus working and the licensing is set up. However, when I attempt to run modelsim, I get an error about the licensing.
First, I tried to run modelsim through the Quartus GUI, which generated the attached report.
Then, I attempted to run it through command line with ./vsim and this produced the following output:
$ ./vsim
Unable to checkout a license. Make sure your license file environment variable (e.g., LM_LICENSE_FILE)
is set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Unable to checkout a license. Vsim is closing.
** Fatal: Invalid license environment. Application closing.
So I checked to make sure my variable existed:
$ echo $LM_LICENSE_FILE
1800@altera02p.elic.intel.com
Then I used lmutil as the above output suggested (I copied the directory I ran this command from too):
~/intelFPGA/18.0/modelsim_ae/linuxaloem$ ./lmutil lmdiag
lmutil - Copyright (c) 1989-2014 Flexera Software LLC. All Rights Reserved.
FlexNet diagnostics on Mon 8/20/2018 14:53
License file: 1800@altera02p.elic.intel.com
"6AF7_00DD" v2019.04, vendor: alterad, expiry: 1-jan-0
 License server: fmylic7008.fm.intel.com
 floating license no expiration date
This license can be checked out
And this is where I felt stuck. It appears that the diagnostic tool does not believe anything is wrong, so what could be causing this? Any assistance would be greatly appreciated.
Best Regards, Alex
CalvinJoaz_P_Intel
Hi Milleral,
If you're an Inten at Intel, kindly contact your supervisor related to this issue or
can you provide your Intel e-mail ID?
CalvinJoaz_P_Intel
Hi Milleral,
Alexander_M_Intel
Hello Calvin, my supervisor is the one that advised me to post my issue on this forum. My email ID is Removed
Thanks, Alex
