17091 Discussions
modelsim megawizard dpram no output
first change
init_file => "./souce/memory.mif" in dpram_2200.vhd
to absolute dir
then run modelsim,
you will find out that output :vector q are always 0,this is incorrect,for I have initialized some datas in mif.how to explain it?
Details are in attchment.
(Virus scan in progress ...)
Tools have their own mind. Modelsim does not like mif as far as i know. Go to quartus and save it as hex then come back to Modelsim
--- Quote Start ---
--- Quote End ---
I have tried "hex file" before ,but it doesnt work as well
Check modelsim compilation report if it sees the memory module and the hex file. Otherwise it will still report success but with memory as black box.
one warning in modelsim# ** Warning: Warning: READ_DURING_WRITE_MODE_MIXED_PORTS is assumed as OLD_DATA# Time: 0 ps Iteration: 0 Instance: /dpram_test_top_tb/uut/dpram_2200_inst/altsyncram_component
photo 0f results in attachment
