17255 Discussions
multiplication of unsigned and sfixed numbers
I am trying to multiply an unsigned number with sfixed number (0.703125). following are the code and errors:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
USE ieee.numeric_std.all;
entity tryproduct is
end tryproduct;
architecture Behavioral of tryproduct is (Line 11)
signal a : sfixed(0 downto -6);
signal k : sfixed(8 downto -6);
SIGNAL temp1: UNSIGNED (8 downto 0) := "101001001" ;
begin
a <= to_sfixed (0.703125,a);
k <= to_sfixed(temp1) * a; (Line 19)
end Behavioral;
Errors:
ERROR:HDLCompiler:432 - "G:/vhdlcodes/producttry/tryproduct.vhd" Line 19: Formal <arg> has no actual or default value.
ERROR:HDLCompiler:841 - "G:/vhdlcodes/producttry/tryproduct.vhd" Line 19: Expecting type integer for <temp1>.
ERROR:HDLCompiler:9 - "G:/vhdlcodes/producttry/tryproduct.vhd" Line 19: Found 0 definitions for operator "*".
ERROR:HDLCompiler:854 - "G:/vhdlcodes/producttry/tryproduct.vhd" Line 11: Unit <behavioral> ignored due to previous errors.
thanks in advance
Please dont cross post - there are many solutions on your post here: http://www.edaboard.com/thread353788.html
