16606 Discussions
peak wire utilization 100% over
sakrin
After compiling a design, I looked at the Global Router Wire Utilization Map and saw that some of the utilization exceeded 100%. However, it seems that bitstreams are being generated.
Does this bitstream work properly?
This has been translated into English by a translation site. I apologize if it is incomplete.
RichardTanSY_Intel
The Global Router Wire Utilization Map gives a visual representation of estimated wire usage on the chip and give detailed information about what might be causing the route congestion.
Unless there is a fitter error saying unsuccessful, it should Not impact the bitstream generated once compilation passed.
RichardTanSY_Intel
sakrin
