16597 Discussions
please help me out with instatiotion problem
i have problem abt the instatiotion, when i run the code i got this message from the quartus II...i make it red where it detects the error...please help me
error: node instance "comp1" instantiates undefined entity "controller"
error: node instance "ram1" instantiates undefined entity "generic_ram"
Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 3 warnings
Error: Peak virtual memory: 238 megabytes
Error: Processing ended: Sun Dec 16 11:23:31 2012
Error: Elapsed time: 00:00:04
Error: Total CPU time (on all processors): 00:00:04
Error: Quartus II Full Compilation was unsuccessful. 4 errors, 3 warnings
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity voice is
generic
( WORD_SIZE : Natural :=8;
RAM_DEPTH : Natural :=32;
ADDRESS_LENGTH : Natural :=5);
port(
test_data : in std_logic_vector ( WORD_SIZE-1 downto 0);
config_in : in std_logic_vector ( WORD_SIZE-1 downto 0);
clk : in std_logic;
nrst :in std_logic;
config : in std_logic;
check : in std_logic;
max_add : in std_logic_vector( ADDRESS_LENGTH-1 downto 0);
--samp_out :in std_logic_vector ( WORD_SIZE-1 downto 0);--from ram
--samp_in :out std_logic_vector ( WORD_SIZE-1 downto 0);--to ram
test_en : out std_logic;
test_rdwr : out std_logic;
test_add : out std_logic_vector( ADDRESS_LENGTH-1 downto 0);
test_ok : out std_logic;
see_result: out std_logic;
seg_addr : out std_logic_vector( ADDRESS_LENGTH-1 downto 0)
end voice;
architecture top of voice is
component GENERIC_RAM is
generic
port( clk : in std_logic;
nrst : in std_logic;
rd_wr : in std_logic;
ram_en :in std_logic;
address : in std_logic_vector( ADDRESS_LENGTH-1 downto 0);
datain: in std_logic_vector ( WORD_SIZE-1 downto 0);
dataout: out std_logic_vector ( WORD_SIZE-1 downto 0)
end component;
component controller
generic
port(
clk : in std_logic;
nrst :in std_logic;
samp_out :out std_logic_vector ( WORD_SIZE-1 downto 0);--from ram
samp_in :in std_logic_vector ( WORD_SIZE-1 downto 0);--to ram
samp_add : out std_logic_vector( ADDRESS_LENGTH-1 downto 0);
samp_en : out std_logic;
samp_rdwr :out std_logic;
end component;
signal address : std_logic_vector(ADDRESS_LENGTH-1 downto
0):=(others=> 'Z');
signal rd_wr : std_logic := 'Z';
signal ram_en : std_logic := 'Z';
signal samp_out : std_logic_vector ( WORD_SIZE-1 downto 0); -- from ram
signal samp_in : std_logic_vector ( WORD_SIZE-1 downto 0); -- from ram
begin
--instatiating controller block
comp1 : controller port map ( test_data => test_data,
config_in => config_in,
clk => clk,
nrst => nrst,
config => config,
check => check,
max_add => max_add,
samp_out => samp_out,
samp_in => samp_in,
test_en => test_en,
test_rdwr => test_rdwr,
test_ok => test_ok,
see_result => see_result,
samp_add => address,
samp_en => ram_en,
samp_rdwr => rd_wr,
seg_addr => seg_addr);
-- instatiating memory block
ram1: generic_ram port map ( clk => clk,
nrst => nrst,
rd_wr => rd_wr,
ram_en => ram_en,
address => address,
datain=> samp_in,
dataout=> samp_out);
end top;
Have you included the source code for "controller" and GENERIC_RAM in your project and compiled them before this code?
no sir i was trying to compile one by one...so it means that i have to compile all the codes in one time....thanks in advance sir
