i have problem abt the instatiotion, when i run the code i got this message from the quartus II...i make it red where it detects the error...please help me
error: node instance "comp1" instantiates undefined entity "controller"error: node instance "ram1" instantiates undefined entity "generic_ram" Error: Quartus II Analysis & Synthesis was unsuccessful. 2 errors, 3 warnings Error: Peak virtual memory: 238 megabytes Error: Processing ended: Sun Dec 16 11:23:31 2012 Error: Elapsed time: 00:00:04 Error: Total CPU time (on all processors): 00:00:04 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 3 warnings library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity voice is generic ( WORD_SIZE : Natural :=8; RAM_DEPTH : Natural :=32; ADDRESS_LENGTH : Natural :=5); port( test_data : in std_logic_vector ( WORD_SIZE-1 downto 0); config_in : in std_logic_vector ( WORD_SIZE-1 downto 0); clk : in std_logic; nrst :in std_logic; config : in std_logic; check : in std_logic; max_add : in std_logic_vector( ADDRESS_LENGTH-1 downto 0); --samp_out :in std_logic_vector ( WORD_SIZE-1 downto 0);--from ram --samp_in :out std_logic_vector ( WORD_SIZE-1 downto 0);--to ram test_en : out std_logic; test_rdwr : out std_logic; test_add : out std_logic_vector( ADDRESS_LENGTH-1 downto 0); test_ok : out std_logic; see_result: out std_logic; seg_addr : out std_logic_vector( ADDRESS_LENGTH-1 downto 0) ); end voice; architecture top of voice is component GENERIC_RAM is generic ( WORD_SIZE : Natural :=8; RAM_DEPTH : Natural :=32; ADDRESS_LENGTH : Natural :=5); port( clk : in std_logic; nrst : in std_logic; rd_wr : in std_logic; ram_en :in std_logic; address : in std_logic_vector( ADDRESS_LENGTH-1 downto 0); datain: in std_logic_vector ( WORD_SIZE-1 downto 0); dataout: out std_logic_vector ( WORD_SIZE-1 downto 0) ); end component; component controller generic ( WORD_SIZE : Natural :=8; RAM_DEPTH : Natural :=32; ADDRESS_LENGTH : Natural :=5); port( test_data : in std_logic_vector ( WORD_SIZE-1 downto 0); config_in : in std_logic_vector ( WORD_SIZE-1 downto 0); clk : in std_logic; nrst :in std_logic; config : in std_logic; check : in std_logic; max_add : in std_logic_vector( ADDRESS_LENGTH-1 downto 0); samp_out :out std_logic_vector ( WORD_SIZE-1 downto 0);--from ram samp_in :in std_logic_vector ( WORD_SIZE-1 downto 0);--to ram test_en : out std_logic; test_rdwr : out std_logic; test_add : out std_logic_vector( ADDRESS_LENGTH-1 downto 0); test_ok : out std_logic; samp_add : out std_logic_vector( ADDRESS_LENGTH-1 downto 0); samp_en : out std_logic; samp_rdwr :out std_logic; see_result: out std_logic; seg_addr : out std_logic_vector( ADDRESS_LENGTH-1 downto 0) ); end component; signal address : std_logic_vector(ADDRESS_LENGTH-1 downto 0):=(others=> 'Z'); signal rd_wr : std_logic := 'Z'; signal ram_en : std_logic := 'Z'; signal samp_out : std_logic_vector ( WORD_SIZE-1 downto 0); -- from ram signal samp_in : std_logic_vector ( WORD_SIZE-1 downto 0); -- from ram begin --instatiating controller block comp1 : controller port map ( test_data => test_data, config_in => config_in, clk => clk, nrst => nrst, config => config, check => check, max_add => max_add, samp_out => samp_out, samp_in => samp_in, test_en => test_en, test_rdwr => test_rdwr, test_ok => test_ok, see_result => see_result, samp_add => address, samp_en => ram_en, samp_rdwr => rd_wr, seg_addr => seg_addr); -- instatiating memory block ram1: generic_ram port map ( clk => clk, nrst => nrst, rd_wr => rd_wr, ram_en => ram_en, address => address, datain=> samp_in, dataout=> samp_out); end top;
Have you included the source code for "controller" and GENERIC_RAM in your project and compiled them before this code?
no sir i was trying to compile one by one...so it means that i have to compile all the codes in one time....thanks in advance sir
