17252 Discussions
prevent auto-inferrence of specific mult-accum?
Hi - does anyone know how to keep Quartus from inferring a mult-accum? I know you can turn it off for the entire design, and I know you can turn it off for a MULT with the multstyle parameter. But I can't seem to keep it from using a hard DSP block for a mult-accum it inferred from logic.
Thanks!
/j
Multstyle synthesis attributes can be also used on design entities (an architecture). In so far you have a means to control DSP inference for part of your design. There may be also indirect ways by "keeping" specific design nodes.
What's the actual problem behind your question?
The actual problem is that I need to prevent auto-inferrence of a specific mult-accum. Found the answer here...
http://quartushelp.altera.com/11.1/mergedprojects/hdl/vhdl/vhdl_file_dir_attribute.htm
