17049 Discussions
problem to change from Quartus 9.0 to Quartus 11.1
hello together,
i want to change my development tool from quartus 9.0 to 11.1_173.
in the moment i can build my core in SOPC and it is possible to import this core in NIOS IDE 11.1.
But if i want to compile the nios application with the bsp in NIOS IDE i get messages from console "CreateProcess(...) failed.", "make (e=87): wrong parameter." and "make: *** [*.elf] Error 87"
I was change the Settings for the builder settings generally to start the build process so is it necessary to set even more points?
Is there any idea or experience with a changing of the development tools quartus to a higher versions
look into the dokument:
Quartus II Software Version 11.1 Release Notes.
My Altera FAE told me that there are some errors in this version.
One error is:
"Designs that contain a DCFIFO megafunction might fail in hardware" !
My Altera FAE advised me not to use Quartus 11.1.
I have to use 11.1 SP1
i don't think this is related to the DCFIFO issue
is it reasonable to recreate the project in Nios II SBT from scratch instead of importing an IDE project?
