hello to everyone! i am a quartus II newbie. My first exercise on this program is to build an EXOR port. After having connected everything i started compilation which was succefully completed. After this i started simulation waveform editor and i create a waveform. Saved everithing and started a functional simulation. It cannot be finished due to two errors. IMPORTANT: i'm running quartus II on parallel Desktop because i have a Macbook pro and a 32bit win-7 pc which doesn't allow me to work with quartus II. Here attached the simulation flow progress:
Determining the location of the ModelSim executable... Using: c:/altera/14.1/modelsim_ase/win32aloem/ To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options Note: if both ModelSim-Altera and ModelSim executables are available, ModelSim-Altera will be used. **** Generating the ModelSim Testbench **** quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog --write_settings_files=off uno -c uno --vector_source="//psf/Home/Desktop/università/Digilab/1/uno.vwf" --testbench_file="//psf/Home/Desktop/università/Digilab/1/simulation/qsim/uno.vwf.vt" Info: ******************************************************************* Info: Running Quartus II 64-Bit EDA Netlist Writer Info: Version 14.1.0 Build 186 12/03/2014 SJ Web Edition Info: Copyright (C) 1991-2014 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus II License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Wed Mar 09 18:21:18 2016 Info: Command: quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog --write_settings_files=off uno -c uno --vector_source=//psf/Home/Desktop/università/Digilab/1/uno.vwf --testbench_file=//psf/Home/Desktop/università/Digilab/1/simulation/qsim/uno.vwf.vt Warning (201007): Can't find port "y" in design Warning (201005): Ignoring output pin "y" in vector source file when writing test bench files Info (201000): Generated Verilog Test Bench File //psf/Home/Desktop/università/Digilab/1/simulation/qsim/uno.vwf.vt for simulation Info: Quartus II 64-Bit EDA Netlist Writer was successful. 0 errors, 2 warnings Info: Peak virtual memory: 599 megabytes Info: Processing ended: Wed Mar 09 18:21:19 2016 Info: Elapsed time: 00:00:01 Info: Total CPU time (on all processors): 00:00:01 Completed successfully. Completed successfully. **** Generating the functional simulation netlist **** quartus_eda --write_settings_files=off --functional=on --flatten_buses=off --simulation --tool=modelsim_oem --format=verilog --output_directory="//psf/Home/Desktop/università/Digilab/1/simulation/qsim/" uno -c uno Info: ******************************************************************* Info: Running Quartus II 64-Bit EDA Netlist Writer Info: Version 14.1.0 Build 186 12/03/2014 SJ Web Edition Info: Copyright (C) 1991-2014 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus II License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Wed Mar 09 18:21:20 2016 Info: Command: quartus_eda --write_settings_files=off --functional=on --flatten_buses=off --simulation=on --tool=modelsim_oem --format=verilog --output_directory=//psf/Home/Desktop/università/Digilab/1/simulation/qsim/ uno -c uno Info (204019): Generated file uno.vo in folder "//psf/Home/Desktop/università/Digilab/1/simulation/qsim//" for EDA simulation tool Info: Quartus II 64-Bit EDA Netlist Writer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 603 megabytes Info: Processing ended: Wed Mar 09 18:21:21 2016 Info: Elapsed time: 00:00:01 Info: Total CPU time (on all processors): 00:00:01 Completed successfully. **** Generating the ModelSim .do script **** //psf/Home/Desktop/università/Digilab/1/simulation/qsim/uno.do generated. Completed successfully. **** Running the ModelSim simulation **** c:/altera/14.1/modelsim_ase/win32aloem//vsim -c -do uno.do Reading C:/altera/14.1/modelsim_ase/tcl/vsim/pref.tcl # 10.3c # do uno.do# ** Warning: (vlib-34) Library already exists at "work".# # Model Technology ModelSim ALTERA vlog 10.3c Compiler 2014.09 Sep 20 2014# Start time: 18:21:22 on Mar 09,2016# vlog -work work uno.vo # init_dbinfo() DATABASE ERROR: (sqlite3_open //psf/Home/Desktop/università/Digilab/1/simulation/qsim/work/_lib.qdb): unable to open database file# mtilibWrite(): Unexpected null object encountered# ** Fatal: (vlog-9) Problem while writing token file "//psf/Home/Desktop/università/Digilab/1/simulation/qsim/work/_temp/vlog9ttz2d".# # The system cannot find the path specified. (GetLastError() = 3)# ** Error: uno.vo(32): Verilog Compiler exiting # End time: 18:21:22 on Mar 09,2016, Elapsed time: 0:00:00 # Errors: 2, Warnings: 0 # ** Error: c:/altera/14.1/modelsim_ase/win32aloem/vlog failed. # Executing ONERROR command at macro ./uno.do line 3 Error.Link Copied
I m having the same problem, can anyone help, below a piece of the information where the error appear:
# init_dbinfo() DATABASE ERROR: (sqlite3_open C:/Users/Bruno Otávio/Documents/FPGA/TesteModelsim/simulation/modelsim/rtl_work/_lib.qdb): unable to open database file
# mtilibWrite(): INTERNAL ERROR: Unexpected null object encountered
# ** Fatal: (vcom-9) Problem while writing token file "C:/Users/Bruno Otávio/Documents/FPGA/TesteModelsim/simulation/modelsim/rtl_work/_temp/vcomre2tad".
# O sistema não pode encontrar o caminho especificado. (GetLastError() = 3)
Hi, I have the same problem:
C:/intelFPGA_lite/19.1/modelsim_ase/win32aloem/vsim -c -do casevirtual.do
Reading C:/intelFPGA_lite/19.1/modelsim_ase/tcl/vsim/pref.tcl
# 10.5b
# do casevirtual.do
# Model Technology ModelSim - Intel FPGA Edition vcom 10.5b Compiler 2016.10 Oct 5 2016
# Start time: 22:48:47 on Apr 15,2020
# vcom -work work casevirtual.vho
# -- Loading package STANDARD
# init_dbinfo() DATABASE ERROR: (sqlite3_open D:/ACER_WILSON/Ingeniería Electrónica Compartido/8° Semestre/Prototipado Rápido y VHDL/casevirtual/simulation/qsim/work/_lib.qdb): unable to open database file
# ** Fatal: (vcom-9) Problem while writing token file "D:/ACER_WILSON/Ingeniería Electrónica Compartido/8° Semestre/Prototipado Rápido y VHDL/casevirtual/simulation/qsim/work/_temp/vcom2erff3".
# El sistema no puede encontrar la ruta especificada. (GetLastError() = 3)
# ** Error: casevirtual.vho(30): VHDL Compiler exiting
# End time: 22:48:47 on Apr 15,2020, Elapsed time: 0:00:00
# ** Error: C:/intelFPGA_lite/19.1/modelsim_ase/win32aloem/vcom failed.
# Executing ONERROR command at macro ./casevirtual.do line 3
Error.
I did solve it changing the directory of project.
The directory's name would be not contain special characters (like ticks or underscores)
In case anyone finds this error message and wants to know the solution: all the previous users had accents in their project paths. ModelSim doesn't support them, just plain ASCII.
Thank you oriolaecas for the trick. It works for me!
