16976 Discussions
project_new -family Agilex detected as Cyclone 10 GX
alexislms
Valued Contributor I
project_new agilex_r29a -overwrite -family Agilex
Why Cyclone 10 GX?
"-family Agilex" is requested
SyafieqS
Alexis,
Alternatively you can use global assignment to set the device family in tcl script
set_global_assignment -name family AGILEX
sstrell
So you're trying to target Agilex and it wants to use Cyclone 10 GX?  Can you successfully set up a new project like this with the New Project Wizard instead of a command?
alexislms
Not at all, I don't even know from where Quartus takes the Cyclone 10 GX...
As anybody can see, there is no mention of Cyclone in the command, only agilex.
What's wrong with my command?
sstrell
Understood, but as a test, can you successfully create a new project with Agilex using the New Project Wizard instead of a command?
alexislms
Yes, no problem from the wizard.
You can easily reproduce it by opening quartus and running my single line command.
SyafieqS
Alexis,
Is this new first time issue encounter?
What Quartus version is this? Might be a bug CLI for the build. (ill reproduce this)
Is wizard feasible for current workaround?
alexislms
I just started to use the Intel toolset for the Agilex I-series devkit, therefore this is the first time I encounter it.
I use the latest Quartus Pro version 22.1.
It's fine for now but we definitely need to be able to create project for Agilex from tcl.
I wonder how much QP22.1 was tested, it fails at the first command to create a project...
Thanks for your help.
SyafieqS
Hi Alexis,
I recommended you to use wizard as a temporary workaround and truly apologize for the inconvenience experience.
I filed a bug report to developer regarding the cli.
Let me know if there is any other concern.
SyafieqS
Alexis,
SyafieqS
Hi Alexis,
May I know if there is any update or concern on this?
alexislms
@SyafieqS Feel free to close this issue. I just reported the bug.
Thank you for your help.
SyafieqS
I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
