17251 Discussions
quartus II subscription edition trial
How I am able to get Quartus II subscription edition 30 trial version with programming file support??? Is it possible? I am don't wish to buy a paid version now.
please replay
Thank you
Download the subscription edition. Install it. Under 'Tools' -> 'License Setup...' click on the 'Begin 30-day Grace Period' button.
Alex
Thank you....
Before that I need to activate license or not??? activating license of product ( QUARTUS & device) or computer???? How can I do that? This is my first work. please replay.
please replay
Thank you
You don't need to pre-activate it. Download it, install it, then activate your free trial. As long as you haven't used a free trial on your machine before it will work.
Alex
How to activate free trial.?? I installed ,but it not supporting programming file. Not able to select "'Begin 30-day Grace Period'.
please reply
Thank you
When start the Quartus II software, asked
1. run in evaluation mode for 30 days------ It not supporting programming file, so I try to select 2
2. perform an automatic license retrieval from the Altera web site---------- when I try to select it getting message that I am not able to connect altera site.
3.specify the correct location of a valid license file.---------- this option I can't try since I don't have license file.
I downloaded subscription version from site. wheather the license is attached with downloaded data? so that I can try 3rd option again.
please help how can I use trial version with programming file support?
thank you
Like Alex has said:
go to tools -> licence setup -> begin 30 day grace period.
You do not need a licence to begin this. You can only do this once!
Otherwise you need to purchase a full licence.
But sir I am not able to select "begin 30 day grace period" in license setup. what will be the reason?. please help me.
Thank you
Havwe you used a trial previously?
No sir....
no sir...
Thankyou
Sir,
1. started quartus II software
2.a menu comes includes 3 options---30 days trial without programming file, AUTOMATIC LICENSE RETRIEVAL,SELECT LICENSE LOCATION ---I SELECTED first option
3.license setup...30 day grace period ,am not able to select
what will be the reason ? I am using trial first time.
The only reason I know of is that you have activated the 30 day licences previously on this computer. You may need to file a my support request on the altera website
https://www.altera.com/myaltera/mal-index.jsp
I have the exact same problem here :/
Sorry all!
I want to buy DSP builder license but I can not find the price in Altera Website. I need to help! Thank all!
You need to contact your local altera distributer.
Yes, contact your local disty as I believe all license/IP purchase need to go through them:
http://wl.altera.com/servlets/contactsales?o=id
I have the same problem here. I have installed the subscription edition 30 Day trial for the first time, but it says Expiration 25-may-2015, so already expired, I have only used the web edition before... Must I first register the NIC on the altera Website ? It's a bit frustrating. Would be great if someone could give me a hint.
Many thanks
Thanks. I got it!
