16608 Discussions
quartus_eda crashes (core dump) very often. I have to clean my project before compile to prevent crash
BLee15
Core dump:
Problem Details Error: Internal Error: Sub-system: WSC, File: /quartus/neto/wsc/wsc_port.cpp, Line: 409 m_port_info.num_of_dimensions() == 1 Stack Trace: 0x54a7: WSC_PORT::left_bit + 0x37 (NETO_WSC) 0x2488f: VLGO_SV_WRITER::write_port_declare + 0x14f (NETO_VLGO) 0x171db: VLGO_WRITER::write_port_declarations + 0xbb (NETO_VLGO) 0x15983: VLGO_WRITER::write_module_declare + 0x133 (NETO_VLGO) 0x1536e: VLGO_WRITER::write_module + 0xde (NETO_VLGO) 0x1241d: VLGO_WRITER::write_file + 0x7ed (NETO_VLGO) 0x1e386: QNETO_START::generate_simulation_files + 0xf86 (quartus_eda) 0x1f61e: QNETO_START::generate_simulation_files + 0x57e (quartus_eda) 0x1726f: QNETO_START::generate_eda_files + 0x2f (quartus_eda) 0x2762c: generate_all_eda_files + 0x4c (quartus_eda) 0x28240: qneto_execute + 0x1a0 (quartus_eda) 0x9b98: QNETO_FRAMEWORK::execute + 0x288 (quartus_eda) 0x112bc: qexe_do_normal + 0x1ec (comp_qexe) 0x16142: qexe_run + 0x432 (comp_qexe) 0x16e51: qexe_standard_main + 0xc1 (comp_qexe) 0xfabd: qneto_main + 0x9d (quartus_eda) 0x12f28: msg_main_thread + 0x18 (CCL_MSG) 0x1470e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x16660: mem_thread_wrapper + 0x70 (ccl_mem) 0x127f1: msg_exe_main + 0xa1 (CCL_MSG) 0x29be2: __tmainCRTStartup + 0x10e (quartus_eda) 0x17bd3: BaseThreadInitThunk + 0x13 (KERNEL32) 0x6cee0: RtlUserThreadStart + 0x20 (ntdll)   End-trace     Executable: quartus_eda Comment: None   System Information Platform: windows64 OS name: Windows 10 OS version: 10.0   Quartus Prime Information Address bits: 64 Version: 18.1.1 Build: 646 Edition: Lite Edition
I attached my project as archive file
Kenny_Tan
Can you provide the exact steps that you have used? I try duplicate it on my side but failed.
BLee15
  1. Restore archived project
  2. Start compilation. This usually success.
  3. Modify top.sv; adding some whitespace would be enough
  4. Start compilation. quartus_eda crashes about 2 out of 3 times.
Kenny_Tan
BLee15
Changing output format to other languages significantly modifies top module interface.
It is hard to accept this workaround, as it brings heavy testbench rework.
Verilog HDL: ​2D array is unrolled to individual single-wire ports
module top ( raw_clock, raw_reset, number, instruction, in_5_1, in_6_1, in_4_1, in_7_1, in_2_1, in_1_1, in_0_1, in_3_1, in_5_0, in_6_0, in_4_0, in_7_0, in_2_0, in_1_0, in_0_0, in_3_0, in_5_2, in_6_2, in_4_2, in_7_2, in_2_2, in_1_2, in_0_2, in_3_2, in_5_3, in_6_3, in_4_3, in_7_3, in_2_3, in_1_3, in_0_3, in_3_3, in_5_4, in_6_4, in_4_4, in_7_4, in_2_4, in_1_4, in_0_4, in_3_4, in_5_5, in_6_5, in_4_5, in_7_5, in_2_5, in_1_5, in_0_5, in_3_5, in_5_6, in_6_6, in_4_6, in_7_6, in_2_6, in_1_6, in_0_6, in_3_6, in_5_7, in_6_7, in_4_7, in_7_7, in_2_7, in_1_7, in_0_7, in_3_7, out_7_0, out_7_1, out_7_2, out_7_3, out_7_4, out_7_5, out_7_6, out_7_7, out_6_0, out_6_1, out_6_2, out_6_3, out_6_4, out_6_5, out_6_6, out_6_7, out_5_0, out_5_1, out_5_2, out_5_3, out_5_4, out_5_5, out_5_6, out_5_7, out_4_0, out_4_1, out_4_2, out_4_3, out_4_4, out_4_5, out_4_6, out_4_7, out_3_0, out_3_1, out_3_2, out_3_3, out_3_4, out_3_5, out_3_6, out_3_7, out_2_0, out_2_1, out_2_2, out_2_3, out_2_4, out_2_5, out_2_6, out_2_7, out_1_0, out_1_1, out_1_2, out_1_3, out_1_4, out_1_5, out_1_6, out_1_7, out_0_0, out_0_1, out_0_2, out_0_3, out_0_4, out_0_5, out_0_6, out_0_7);
VHDL: Introduces user-defined type, and kind of output port is changed to BUFFER.
PACKAGE top_data_type IS   TYPE \in\_7_0_type IS ARRAY (7 DOWNTO 0) OF std_logic; TYPE \in\_7_0_0_7_type IS ARRAY (0 TO 7) OF \in\_7_0_type; SUBTYPE \in\_type IS \in\_7_0_0_7_type;   TYPE \out\_7_0_type IS ARRAY (7 DOWNTO 0) OF std_logic; TYPE \out\_7_0_0_7_type IS ARRAY (0 TO 7) OF \out\_7_0_type; SUBTYPE \out\_type IS \out\_7_0_0_7_type;   END top_data_type;   ENTITY top IS PORT ( raw_clock : IN std_logic; raw_reset : IN std_logic; number : BUFFER std_logic_vector(7 DOWNTO 0); instruction : IN std_logic_vector(15 DOWNTO 0); \in\ : IN \in\_type; \out\ : BUFFER \out\_type ); END top;
Kenny_Tan
Any concern if you use the clean project? Currently, Quartus std are in the lower priority on the fixes.
BLee15
I have to do "modify - compile - core dump - clean project - compile - simulation" cycle instead of "modify - compile - simulation".
Is there any option to clean project automatically before compile?
Kenny_Tan
You can write a tcl scripts for it if you want to have the compiles goes with clean project.
Kenny_Tan
let me know if you have trouble to write the tcl scripts?
Kenny_Tan
any update?
BLee15
I'm learning TCL scripts / commands.
One question: can I add my custom TCL scripts to menu bar and/or toolbar, so that I can click the menu/icon to execute my script?
Kenny_Tan
        usually, for this type of script is no. But you can run it in the command prompt and it only take one click.
However, you can always explore yourself. If you successfully created this scripts, all you need to do is goto tools -> tcl script
we created a scripts for you, please note that you may have to create it next time. You can run it with:
cd to quartus install directory where the quartus_sh exist:
quartus_sh -t compile.tcl
