I notice that even though I installed the quartus lite - when I am running through an example on the DE10-Nano, a particular command (quartus_cpf) says "You have 7 days remaining (until May 16, 2018) to use..." Should the lite version stop working in this way? I posted the output below for reference.... Please help! Thanks! lefty D:\projects\DE10-Nano\Demonstrations\SoC_FPGA\Nios_Access_DDR3\demo_batch>sof_to _rbf D:\projects\DE10-Nano\Demonstrations\SoC_FPGA\Nios_Access_DDR3\demo_batch>C:\int elFPGA_lite\17.1\quartus\\bin64\\quartus_cpf -c -o bitstream_compression=on DE10 _NANO_SoC_GHRD.sof soc_system.rbf Info: ******************************************************************* Info: Running Quartus Prime Convert_programming_file Info: Version 17.1.1 Internal Build 593 12/11/2017 SJ Lite Edition Info: Copyright (C) 2017 Intel Corporation. All rights reserved. Info: Your use of Intel Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Intel Program License Info: Subscription Agreement, the Intel Quartus Prime License Agreement, Info: the Intel FPGA IP License Agreement, or other applicable license Info: agreement, including, without limitation, that your use is for Info: the sole purpose of programming logic devices manufactured by Info: Intel and sold by Intel or its authorized distributors. Please Info: refer to the applicable agreement for further details. Info: Processing started: Wed May 09 17:07:53 2018 Info: Command: quartus_cpf -c -o bitstream_compression=on DE10_NANO_SoC_GHRD.sof soc_system.rbf Info (292036): Thank you for using the Quartus Prime software 30-day evaluation. you have 7 days remaining (until may 16, 2018) to use the quartus prime software with compilation and simulation support. Info: Quartus Prime Convert_programming_file was successful. 0 errors, 0 warning s Info: Peak virtual memory: 285 megabytes Info: Processing ended: Wed May 09 17:07:58 2018 Info: Elapsed time: 00:00:05 Info: Total CPU time (on all processors): 00:00:04 D:\projects\DE10-Nano\Demonstrations\SoC_FPGA\Nios_Access_DDR3\demo_batch>pause Press any key to continue . . . D:\projects\DE10-Nano\Demonstrations\SoC_FPGA\Nios_Access_DDR3\demo_batch>echo % QUARTUS_ROOTDIR% C:\intelFPGA_lite\17.1\quartus D:\projects\DE10-Nano\Demonstrations\SoC_FPGA\Nios_Access_DDR3\demo_batch>
I'm having the same problem. I thought Quartus Lite was free forever, not for 30 days. This message seems to imply it's not. Info (292036): Thank you for using the Quartus Prime software 30-day evaluation.
I don't understand if I need to buy a license for Standard or Pro
I'm also interested in this subject. Do you have any update on this? Did Quartus really stop working after 30days? Thanks.
