15894 Discussions
quartus or signal tap.
Raphy
any change that i make in signal tap , without connection the project , the project download but nothing is working.
my way to overcome it until now, i create qar file , before create  signal tap .
Regards Raphy
sstrell
Can you clarify a bit more what the issue is here?
Raphy
Hi .
Details :
Quartus  version 18.1 .
Fpga  board  de10 NANO .
I program the device include the  signal tap as usual work.
The project has to operates few things , include Motor.
all peripheral devices are working as expected .
 now, after make any change in the signal tap , for example delete or add signal , after compile it, nothing are worked.
I think there is any bug in the signal tap.
More of that , from my experience , any project automatic I add Qar file .
I recovery the project by QAR file.
Regards Raphy.
sstrell
Try disabling Signal Tap in the project, recompile and see if it works.  You could have a corrupted .stp file.
RichardTanSY_Intel
When you say nothing works, may I know what is not working? Program the device fail? data acquire fail? if any, what is the error that you are seeing?
Try to start fresh with a new .stp file using the different node/signal and see if the same issue persists.
RichardTanSY_Intel
I have yet to receive any response from you. With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
