I am trying to create a jenkins script to build an existing quartus project. The following command works correctly from command line but when the same is added as a command in Jenkins job it doesn't work.
Command : /p/psg/swip/releases6/acdskit/22.4/94/linux64/quartus/linux64/quartus_sh --flow compile cxltyp2_ed.qpf
Other commands for setting env varibales
Jenkins console output:
The commands start off correctly
But the job finishes without actually doing anything. The project is not compiled and no output_files folder created.
