quartus
david8
I am unable to get my Quartus to work. I was told to download a support software and When I did that it still said the same thing. Does anyone know what I can do to fix it?
sstrell
Need more info.  Error messages, detailed steps of what you've tried etc.
david8
ok so when I use the app and go to start a new project it tells me I need support devices installed and gives me a link to install it. Then I go to the link and install the devices and the same message shows telling me to download support. I have downloaded ever support they have I have uninstalled the app and downloaded it again.
sstrell
What download links are you using?  Quartus version?  Devices you're trying to install?  You're not giving much info to go on here.
david8
Sorry bout that, I have downloaded Arria II, Cyclone IV, Cyclone 10, Cyclone V, Max II, Max V, and Max 10. This is the link I used to find them.  https://fpgasoftware.intel.com/?edition=lite . Also I am using Quartus Prime Lite edition version 20.1
sstrell
So you're saying you successfully downloaded Quartus and devices (.qdz files) and installed the devices, but the tool is still telling you that device support is not installed?
Try accessing and running the device installer directly at <Quartus installation directory>/quartus/common/devinfo/dev_install.
