17049 Discussions
questa: how to add command line option to modelsim.ini
dsula1
For vlog compiler there's -svinputport command line options to select certain behavior. The default is -svinputport=relaxed.
I would like to change the default to -svinputport=net.
Is it possible to add this command line to the modelsim.ini file to change the default behavior? I wasn't able to find anything in the documentation.
Thank you
dsula
ShengN_Intel
Hi dsula,
Try to add svinputport = net under [vlog] in modelsim.ini. Let me know if this helps?
Sheng
dsula1
Unfortunately adding svinputport = net doesn't work. Thank you very much for your reply.
I scoured the documentation. It doesn't seem possible. I guess I have to add it to the command line scripts.
