17255 Discussions
"negative" required longest p2p time
Hello, everybody.
I've a small problem with Quartus II message report.
First of all, when I compile my project, time requirements are not met.
I read the report and I found a lot of errors related to "Setup Time".
I think there's a problem with required longest p2p time, because it has a negative value.
Obviously, "actual longest p2p time" can't be a negative number and so all goes wrong.
Could someone help me about this?
If you need more information, please ask and i'll give you. At the moment I don't know what is useful or not.:p
Thanks in advance,
Alessio.
--- Quote Start ---
Hello, everybody.
Thanks in advance,
Alessio.
--- Quote End ---
Hi Alessio,
which timing analyzer did you use ? Classic Timing Analyzer ?
I assume you have specified at least your required clock speed and the report shows you that your design is too slow ???
Kind regards
GPK
--- Quote Start ---
Hi Alessio,
Kind regards
GPK
--- Quote End ---
Hi pletz,
thank you for the answer.
I specified "default required fmax" to 96 MHz (the frequency I need) and nothing more.
A colleague suggest me to ignore these messages, at the moment, because it may be I don't specify all the requirements that Quartus needs.
I think it is possible so...I'll try to set all the parameters I can.
Thank you again.
Alessio.
--- Quote Start ---
Hi pletz,
Thank you again.
Alessio.
--- Quote End ---
Hi Alessio,
don't forget to set at least:
Settings -> Analyse & Synthesis Settings -> Optimization Technique -> Speed
Settings -> Fitter Settings -> Fitter Effort -> Standard Fit
--- Quote Start ---
Hi Alessio,
--- Quote End ---
Ok,
I do it now.
Thank you, again. :)
Hi, everybody.
Finally I found my problem. At the end of compilation I read:
warning: found 1 node(s) in clock paths which may be acting as ripple and/or gated clocks -- node(s) analyzed as buffer(s) resulting in clock skew
info: detected ripple clock "generatore_clock:inst|divisore_clock:inst4|clk_out" as buffer
Quartus Help suggested me to set constraints for the suspect clock.
Once I did it, all went right.
Thank you all for your support.
See you.
Bye bye,;)
Alessio.
********************Thread Closed********************
