Hi
I am using quartus II 7.1 version for the first time and when i tried to compile my bdf design i am getting the below stated error which says that the name of the bus desclared is illegal cud some one help me out in this .... Error Error: Illegal wire or bus name "regsig3(33..0)" of type signalLink Copied
Try not to end busses with a number.
If you really like the name you have, then rename it as follows: regsig3_bit I have seen many tools get hung up this, as the expansion can make other similar names colide. Avatar- Mark as New
I think the parentheses are wrong too, as they should be square brackets. (I understand the urge to end signals with a number, so maybe add an underscore after it, like regsis3_[33:0], and that should hopefully work.)
Topic Options
