Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
rav
Hi
I am trying to simulate a module with quartus II 7.1 version simulator and i am getting the below stated error, cud someone help me out........
Error: Run Generate Functional Simulation Netlist (quartus_map convl_blk --generate_functional_sim_netlist) to generate functional simulation netlist for top level entity "convl_blk" before running the Simulator (quartus_sim)
rgds rav
Highlighted
Before you run functional simulation using QII simulator, goto the Menu "Processing-> Generate Functional Simulation Netlist.
Hope it helps.
Highlighted
Hi Gurudog
thanks a lot for the reply post..........its now working
rgds rav
Highlighted
TO_BE_DONE
