How much RAM do you have? I'd also suggest removing the spaces from your project path. I doubt that's the issue, though.
And it looks like synthesis is working but not the Fitter. Are you able to fully compile any projects at all? Could be a bad Quartus install.
Am not able to run any of the projects.problem is with compile design and cleared chache.still it is not working
Hi Umasree,
Make sure your RAM meet the requirement for you project in term of device you used. I believe this could be due to this. Not able to run any project at all is very weird, supposed small design can pass the flow even you have a small RAM. Suggestion is to reinstall and check all requirement is met. Another way, try to clean .cdb file and database and recompile.
