17117 Discussions
saving the examined data of Max V failed --- in the Intel Quartus Prime lite 22.1
TN-Notebooks
Hallo
for repair purposes i need to clone  Max V  5M80ZE64C5N
I do not need to change anything and do not want to programm anything - just need clones.
Installed Quartus Prime Lite 22.1
Created a Project by wizzard - selected the correct Chip
Open the Programmer -  Add device  - select chip
check the box for Examine and start
Progress 100 % success
fine until here
now i can not save the File
Right klick on "untitled1.pof - save File  results in
and Quartus closes at all
same Issue like in Standard Edition and not solved for Lite Edition?
https://www.intel.com/content/www/us/en/support/programmable/articles/000094118.html
Report :
Problem Details
Error:
Internal Error: Sub-system: AFCQ, File: /quartus/gcl/afcq/afcq_file_dlg.cpp, Line: 378
QFileDialog layout has changed
Stack Trace:
0x25da6: AFCQ_FILE_DLG::create_checkbox + 0x66 (GCL_AFCQ)
0xcfd8: Ui_MDB_EXPORT_DB_DLG::setupUi + 0x448 (sys_mdb)
0xdbc5: MDB_FILE_NEW_DLG::MDB_FILE_NEW_DLG + 0x2b5 (sys_mdb)
0x7a476: PGMWQ_FRAME_WND::on_save_file_action + 0x36 (pgm_pgmwq)
0x1fb37f: QMimeData::urls + 0x13bf (Qt5Core)
0x6c96: QAction::activate + 0x136 (Qt5Widgets)
0x161d17: QMenu::actionGeometry + 0x457 (Qt5Widgets)
0x161b85: QMenu::actionGeometry + 0x2c5 (Qt5Widgets)
0x167298: QMenu::mouseReleaseEvent + 0xb8 (Qt5Widgets)
0x397d5: QWidget::event + 0x145 (Qt5Widgets)
0x16348b: QMenu::event + 0x17b (Qt5Widgets)
0x1737c: QApplicationPrivate::notify_helper + 0x13c (Qt5Widgets)
0x15080: QApplication::notify + 0x7d0 (Qt5Widgets)
0x1dae38: QCoreApplication::notifyInternal2 + 0xb8 (Qt5Core)
0x186e1: QApplicationPrivate::sendMouseEvent + 0x331 (Qt5Widgets)
0x618cd: QSizePolicy::QSizePolicy + 0x278d (Qt5Widgets)
0x5fb26: QSizePolicy::QSizePolicy + 0x9e6 (Qt5Widgets)
0x1531e: QApplication::notify + 0xa6e (Qt5Widgets)
0x5bf63: QGuiApplicationPrivate::processMouseEvent + 0x723 (Qt5Gui)
0x4726a: QWindowSystemInterface::sendWindowSystemEvents + 0x9a (Qt5Gui)
0x22835d: QEventDispatcherWin32::processEvents + 0xbd (Qt5Core)
0x5a4e8: qt_plugin_query_metadata + 0x1dc8 (qwindows)
0x1d6c60: QEventLoop::exec + 0x1a0 (Qt5Core)
0x1639c7: QMenu::exec + 0x1c7 (Qt5Widgets)
0x1637ba: QMenu::exec + 0x1a (Qt5Widgets)
0x39dc4: QWidget::event + 0x734 (Qt5Widgets)
0xdcb66: QFrame::event + 0x36 (Qt5Widgets)
0x243ce8: QAbstractItemView::viewportEvent + 0x318 (Qt5Widgets)
0xba7b8: AFCQ_TREE_VIEW::viewportEvent + 0x2a8 (GCL_AFCQ)
0x1dd703: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0xe3 (Qt5Core)
0x17368: QApplicationPrivate::notify_helper + 0x128 (Qt5Widgets)
0x158b6: QApplication::notify + 0x1006 (Qt5Widgets)
0x62137: QSizePolicy::QSizePolicy + 0x2ff7 (Qt5Widgets)
0x1d9b2a: QCoreApplication::exec + 0x14a (Qt5Core)
0x10bb: qgq_main + 0x8b (quartus)
0x13538: msg_main_thread + 0x18 (CCL_MSG)
0x1484e: msg_thread_wrapper + 0x6e (CCL_MSG)
0x18210: mem_thread_wrapper + 0x70 (ccl_mem)
0x12cf1: msg_exe_main + 0xa1 (CCL_MSG)
0x20c6: WinMain + 0x156 (quartus)
0x16d2: __scrt_common_main_seh + 0x116 (quartus)
0x17613: BaseThreadInitThunk + 0x13 (KERNEL32)
0x526b0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 22.1std.2
Build: 922
Edition: Lite Edition
TN-Notebooks
Tested with
Intel® Quartus® Prime Programmer and Tools
Version 22.1  -> same Failure
Tested wit
Version 17.1.1 saving possible
but after saving
Max V 5M80ZE64C5N examine / Verify Failure
Still saving File Problems ?
see
https://community.intel.com/t5/Programmable-Devices/Max-V-5M80ZE64C5N-examine-Verify-Failure/m-p/1514585/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExMRFY5N01OTVhZQkhPfDE1MTQ1ODV8U1VCU0NSSVBUSU9OU3xoSw#M92089
NurAiman_M_Intel
Thank you for contacting Intel community.
Progress 100% success
From the steps mention above, you mention that you have check the 'examine' box and start. However in the photo, I did not see the examine box has been checked. Is the photo correct?
Can you provide us the .qar file for your design? So we can tested from our end.
Aiman
TN-Notebooks
Hallo
Regarding the Photo : the check Boxes change after examine.  On the Photo the Result is shown.
I have no .qar File because i just want to readout and clone the Chip.
You can confirm this behavior with every chip you have.
Check the Link in the text  - this is a known Bug from Versions 18.1 and up ? already.
additional i open a further Issue
here you see some more Photos .
Tom
NurAiman_M_Intel
I am checking this with our engineering team. I will get back to you for the findings.
Aiman
NurAiman_M_Intel
This case is different from the KDB link that you have mentioned. The KDB is regarding examining the data from a CFI flash.
However, this case is examining the data from the internal flash of Max V.
Could you provide the stack trace by clicking the "Preview Report..." button on the Quartus Prime Problem Report dialog box?
Is the issue intermittent?
Our engineering team has tested this and they do not get similar issue.
Aiman
NurAiman_M_Intel
Any update for this case?
Aiman
NurAiman_M_Intel
Aiman
TN-Notebooks
Hallo
At the End the Report of 22.1std.2
Saving Failed
Additional Tests :
Tested with
Tested with
Version 20.4  saving possible
Tested with
but after saving
Still examine or saving File Problems ?
see
Report
Problem Details
Error:
Stack Trace:
    0x8cfd8: PGMWQ_DEVICE_TREE::save_file + 0x188 (pgm_pgmwq)
    0x8dbc5: PGMWQ_DEVICE_TREE::save_file + 0x145 (pgm_pgmwq)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Address bits: 64
Version: 22.1std.2
Build: 922
NurAiman_M_Intel
While checking, we found that this problem has been fixed starting from Quartus 23.1 standard version.
Hence if you are using Quartus earlier than 23.1, you can used to save the added ips file into the chain, so that it can restore how you added before. In this way, you can still use the previous added ips.
Aiman
TN-Notebooks
Hallo
i downloaded the 23.2 Pro Version ( without Licence )  and the QuartusProProgrammerSetup-23.2.0.94-windows
With both the Saving of examined Data works now.
But ISP Clamp is grey out and at File no Box.
Thomas
NurAiman_M_Intel
NurAiman_M_Intel
Hi.,
As you can see from the picture above, MAX V is not supported in Quartus Pro version. You will need to use Quartus standard version for this.
Aiman
TN-Notebooks
Hallo
and
no 23.x Versions available
23.x Versions available only for
but the Stand alone Programmer of the Pro Version supports the MAX V
NurAiman_M_Intel
After further checking, Quartus 23.1 for standard version will be release in Quarter 4.
Hence for now, you can used to save the added ips file into the chain, so that it can restore how you added before. In this way, you can still use the previous added ips.
Apologize for the inconveniences.
Aiman
TN-Notebooks
is there also a release Date for the 23.1 Lite version ?
NurAiman_M_Intel
Quartus Lite release will be the same as Quartus standard version.
Aiman
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
