Hi
I have YCbCr video data in two color spaces in sequence(on the same 8bit data bus). I want to separate Y component from CbCr. can you help me please! thank YouLink Copied
If the video is 422 YCbCr you just extract every other data value with a toggling signal.
so you get Y1 Cb1 Y2 Cr1 Y3 Cb2 Y4 Cr2 etc etc- Mark as New
Thank You Tricky for again replying me!
toggling signal?? I am working in dsp builder v6.0. please guide me how is it possible in dsp builder?? actually I want to buffer a full frame (640x480) in real time video and then I have to divide it into blockset i.e 8x8 or 16x16 or 32x32. (I have to do all this in dsp builder) 1st of all I have to separate Y from CbCr.- Mark as New
Your YCbCr signal probably has a data rate of 27MHz (pixel rate x2). You need to create a signal that toggles at 13.5MHz to pick out every Y value from the data stream, because thats how fast it change.
All you need is a signal that looks something like this in VHDL:
process(clk, reset)
begin
if reset = '1' then
y_valid <= '0';
elsif rising_edge(clk)
y_valid <= not y_valid;
end if;
end process;
So in DSP builder you just need a register with the input being in inverted version of its output.
--- Quote Start --- A register with the input being in inverted version of its output. --- Quote End --- Why input being in inverted version of its output?? I can not understand it.
You are creating a toggle. You want to select the Y values while ignoring the C values you can use this toggle as the write enable on another register or memory.
have you tried the Color Plane Sequencer?
Hi thepancake!
I am using dsp builder, quartus II v6.0, there is no color plane sequencer.- Mark as New
Hi Tricky!
I have separate Y from CbCr By using 1to2 demux. And I made Y component to zero. Result is: The display is dark but little effects can be feel, when we move camera here and there. Is it prove that Y component are completely separated from CbCr???? Thank You- Mark as New
If you separated the Y component from the input, the output would be very clearly a black and white version of the input.
So unless you are putting a camera in a dark room, maybe you've extracted Cb/Cr instead of Y. But if you did this, you'd have a screen that was mid-grey most of the time.- Mark as New
Hi Tricky!
thanks for your guideline. I have made the following design flow: deinterlacer >> 1to2 demux(y=0,Cb and Cr = real video values) >>chroma resampler >> color space converter >> scaler megacore functions. So it means I have made Y=0, and play the video with just Cb and Cr values. After that I have used color space converter to make it RGB(that is connected to vga). I think it is fine because I set Y=0 (it means brightness=0) so output must be dark(as I brief in last post).- Mark as New
You need Y, Cb and Cr if you are going to colour space convert to RGB. Setting Y to 0 just kills an RGB output. The conversion is done via a matrix transform. But depending on what your input and output are for affects the matrix.
Raw video off a DAC is likely to have Y values in the range 16 to 235. PC monitors often expect the range 0 to 255 for RGB for peak values, so you can either rescale the input to 0 to 255 or use a different matrix for the colour space conversion. The standard matrix for conversion is:
(R) = ( 1.0 , 0.0 , 1.140 , 0.0 ) (Y )
(G) = ( 1.0 , -0.396 , -0.581 , 0.0 ) * (Cb-128)
(B) = ( 1.0 , 2.029 , 0.0 , 0.0)) (Cr-128)
So
R = Y + 1.14(Cr-128)
G = Y - 0.396(Cb-128) - 0.581(Cr-128)
B = Y + 2.029(Cb-128)
TO_BE_DONE
