hi everyone i am new in quartus ii..i like to know is it is possible to save signal tap ii data with time, automatically in a memory location for future use..
please replyLink Copied
I am not entirely sure if I understand your question, but there is a data log checkbox in signaltap. When checked, it will log your signaltap data in your PC when it is triggered.
The log will contain the date/time of the sample. To recall a previous event, just double click on the desired event in the log and the data will be presented to you. (I use this feature when I need to find an event that does not directly correlate to my trigger while using continuous trigger mode) Hope this helps.- Mark as New
thanks for reply
Kosh271
yes its works ..but if i like to collect all the data, from data log to a single table format than it is possible or not ? please kindly tell me
