17254 Discussions
simulation doesn't work well
hi, i asked to build a multiplier 2X4.
my problem, as you can see in the image, that signal s5 starts one cycle before the others.
all the signals connected well and i have no idea why it happend.
i have checked my mul and it works well.
you can see my code and the simulation at the links below.
thanks
Just wonder if it is possible for you to initialize the output value ie to 0 to ensure the output to have same values at the beginning of the simulation.
Its definitely a signal initialisation issue. You need to ensure the values in your testbench that drive your DUT are given initial values.
do you mean that i need to initialize the register?
reser = '0' ?
or initialize the output of the component? and then how i do it?
Usually you can define signal name : type := default_value.
thank you
works well
