simulation license error
cglover
When attempting to run the simulation tool it gives a fatal license error. It seems to be some sort of IP issue. I can utilize the simulation tool only at home but not at school or anywhere else. I am unsure how to solve this issue.
sstrell
Like it says, the license file is for a specific MAC address (locked to a specific ethernet address).  You would need to generate a new file for the computer with the issue.
SyafieqS
Are you using the same license as at home?
If yes, as it says, specific ethernet address only for one license, you need to create another in sslc
cglover
Yes I believe I had already tried doing this. I generated a new license  and implemented it into the  program, but I am still having the same issue.
SyafieqS
Make the path is pointing correctly.
Also, another is try to change the path of the .dat file.
Could be the path does not have permission to read causing the licensing issue.
SyafieqS
Let me know if there is any update
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
