sof file format?
Stratix III Active Serial question:
I would like to know how may bits in my EPCS device I'm actually using given a sof file. How do I do this? If I enable bit stream compression I assume that the number will reduce (seems obvious).
Is there a sof file format document anywhere? I have searched, and can't seem to find anything useful.
I program via the NIOS i.e. using the EPCS controller via JTAG i.e. I don't use a pof file via the EPCS programming header I have on my board.
Dave.
Cause JTAG configuration doen't use compression, *.sof files have always full size. Compression option is valid e.g. for *.pof or *.rbf files. Generally the device handbook tells the size of uncompressed bitstreams.
OK, I just read that I can use the compression option of sof2flash and so get compression that way (hopefully).
I guess I can glean the size of the image from the resulting flash file.
Dave.
Yes, also the Quartus Programming File converter tool, used e.g. to generate *.jic files for programming of AS configuration devices through JTAG does a later compression of bit streams from *.sif files.
