17049 Discussions
sopc design with ddr sdram controller
I am getting the following error when running the sopc design(which has ddr-sdram controller), am I suppose to change anything in the TCL scripts to amke it work?
Error: Analysis and Elaboration failed. The constraints script will not be able to add any constraints.
Error: Tcl error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
while executing
"error $result"
(procedure "check_paths" line 13)
invoked from within
"check_paths $wrapper_name $do_analysis"
invoked from within
"if { $run_var != 0 } {# ########################################################################### Procedure check_paths() will analyse the project..."
(file "add_constraints_for_ddr_sdram_0.tcl" line 74)
invoked from within
"source add_constraints_for_ddr_sdram_0.tcl"
(file "auto_add_ddr_constraints.tcl" line 11)
Error: Evaluation of Tcl script auto_add_ddr_constraints.tcl unsuccessful
Error: Quartus II Shell was unsuccessful. 11 errors, 0 warnings
Error: Peak virtual memory: 60 megabytes
Error: Processing ended: Thu Oct 16 14:09:52 2008
Error: Elapsed time: 00:00:15
Error: Total CPU time (on all processors): 00:00:00
Error: Quartus II Full Compilation was unsuccessful. 13 errors, 0 warnings
Thanks a lot!
Sasi
You should edit the DDR megafunction and click on step 2, labelled constraints.
This will create the "auto_add_ddr_constraints.tcl" which should in turn load the "add_constraints_for_<DDR SDRAM NAME>.tcl" script.
hi
i have the same problem , how can i edit the megafunction plzzzzzzzzzzzzzzzzzzzzzzzzz
:)) thank u
Have a read through Chapter 1 of this document:
http://www.altera.com/literature/hb/external-memory/emi_tut_ddr.pdf
Mark.
