17266 Discussions
system verilog signed'() extended sign bit wrong
RRoma13
module signed_test3(
input logic clk,
input logic [11:0] in,
input logic [11:0] zero,
output logic signed [15:0] d,
output logic signed [15:0] d2
logic signed [15:0] c,c2;
logic signed [11:0] a,b;
always_ff @(posedge clk) begin
a <= in;
b <= signed'( a[11:0] );
c <= ( signed'( b + signed'(zero) ) );
c2 <= ( signed'( b[11:0] + signed'(zero) ) );
end
assign d = signed'( c );
assign d2 = signed'( c2 );
endmodule
if you wrote only name of signed signal synth reduce sum to one bit.
of course all simulators(edaplayground) and Mentor Precision work as described -
12bit of signed "b" + 12 bit signed "zero"  = signed value extended to 16 bit "c".
quartus 21.1
paveetirrasrie_Intel
Hi RRoma13,
I'm unclear about your query. Could you kindly explain further?
Pavee
RRoma13
the apotheosis of this situation
input logic [11:0] a,
input logic [11:0] a1,
output logic [11:0]b,
output logic [11:0]b1
assign b[11:0] = unsigned'({a[11],a[10:0]});
assign b1[11:0] = unsigned'(a1[11:0]);
endmodule
see screenshot of rtl viewer
RRoma13
if this module set as top level in quartus and run synthesis, then  summator for signal c and c2 is different. for c2 is right. but for signal "c" is wrong. quartus reduce result of sum to one bit and connect this bit to all bits of register "c".(see picture of rtl viewer). like c[15:0]={{sum[0]}}.
and all simulators and Mentor Precision work normally, c and c2 is same.
Just wanted to check with you, is your concern has been addressed?
If yes , kindly do let me know.
Thank You
We do not receive any response from you to the previous question that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Intel experts.
Otherwise, the community users will continue to help you on this thread.
Thank you.
