17042 Discussions
task-to stop counter when it reaches "0000"
4 bit down counter
architecture behavioral of dwncounter is
signal counter<= std_logic_vector(3 downto 0);
begin
process(clk, rst)
begin
if (rst='1') then
counter<="0000";
elsif rising_edge(clk) then
if(enable='1') then
counter<=counter-1;
end if;
end if
the task is to stop counter when it reaches "0000" i.e; the signal sholud go low even if the enable signal is high. plzz help...
How about posting your first attempt, and tell us whats wrong...
Why not simply replacing:
if(enable='1')
with:
if (enable='1') and (counter /= "0000") ?
I would also suggest not resetting to 0.
--- Quote Start ---
--- Quote End ---
after the code is compiled when i go for simulation i set the end time as 400ns.. at the rising edge when enable is high the counter starts counting. then when it reaches 0000 it again gets loaded with 1111 and starts counting again.. i dont want the counter to count again even if enable is high..
hii did it.. after simulation the counts appear like this... " F E C D C A B A 8 9 8 6 7 6 4 5 4 2 3 2 0 1 0"
I hve set the end time as 400 ns and start is 0 ps..
wt to do to get proper count..? plzz help
--- Quote Start ---
if(enable='1')
with:
--- Quote End ---
why not post the code you used....
And what is the "proper count"? the code you origionally posted is a down counter.
--- Quote Start ---
--- Quote End ---
I guess he refers to the glitches (or whatever they are) he obtains in the counter every time he has a 1 to 0 transition on bit 0.
@Naeem
add this: signal counter_out<= std_logic_vector(3 downto 0);
and assign: counter_out <= counter;
This way counter_out should display the proper count
--- Quote Start ---
--- Quote End ---
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity dwncounter is
port( clk,rst:in std_logic;
enable:in std_logic;
count:out std_logic_vector(3 downto 0)
end dwncounter;
signal counter:std_logic_vector(3 downto 0):="1111"
begin
process(clk,rst)
begin
if (rst='1') then
counter<=(others=>'0');
if(enable='1'and counter/="0000") then
counter<=counter-1;
end if;
end if;
end process;
count<=counter;
end behavioral;
Your code shows a down counter that only counts when enable is high and counter is not 0.
What about a testbench?
where does the clk come from?
shouldnt you be resetting counter to "1111" rather than "0000"?
