testbench
I wonder what is wrong when i drive modelsim...
here is the testbench code. :confused:
-- Generated on "10/05/2012 12:26:11"
-- Vhdl Test Bench template for design : uppgift_3b
-- Simulation tool : ModelSim-Altera (VHDL)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY uppgift_3b_vhd_tst IS
END uppgift_3b_vhd_tst;
ARCHITECTURE uppgift_3b_arch OF uppgift_3b_vhd_tst IS
-- constants
-- signals
SIGNAL addr_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL addr_rom : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL clk : STD_LOGIC:='0';
SIGNAL data_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL q_ram : STD_LOGIC_VECTOR(2 DOWNTO 0);
SIGNAL q_rom : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL we_ram : STD_LOGIC;
COMPONENT uppgift_3b
PORT (
addr_ram : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
addr_rom : IN STD_LOGIC_VECTOR(1 DOWNTO 0);
clk : IN STD_LOGIC;
data_ram : IN STD_LOGIC_VECTOR(2 DOWNTO 0);
q_ram : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
q_rom : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
we_ram : IN STD_LOGIC
END COMPONENT;
BEGIN
i1 : uppgift_3b
PORT MAP (
-- list connections between master ports and signals
addr_ram => addr_ram,
addr_rom => addr_rom,
clk => clk,
data_ram => data_ram,
q_ram => q_ram,
q_rom => q_rom,
we_ram => we_ram
clk<= not(clk) after 20 ns;
init : PROCESS
-- variable declarations
BEGIN
WAIT FOR 100ns;
addr_ram <= "01";
WAIT FOR 100ns;
addr_rom <= "10";
WAIT FOR 100ns;
data_ram <= "011";
WAIT FOR 100ns;
we_ram <= "1";
-- code that executes only once
WAIT;
END PROCESS init;
END uppgift_3b_arch;
what errors do you get?
# Reading C:/altera/12.0/modelsim_ase/tcl/vsim/pref.tcl # do uppgift_3b_run_msim_rtl_vhdl.do # if {[file exists rtl_work]} {# vdel -lib rtl_work -all# }# vlib rtl_work# vmap work rtl_work# Copying c:\altera\12.0\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini# Modifying modelsim.ini# ** Warning: Copied c:\altera\12.0\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini.# Updated modelsim.ini.# # vcom -93 -work work {C:/altera_trn/VHDL_kurs/uppgift_3b/uppgift_3b.vhd}# Model Technology ModelSim ALTERA vcom 10.0d Compiler 2012.01 Jan 18 2012# -- Loading package STANDARD# -- Loading package TEXTIO# -- Loading package std_logic_1164# -- Loading package NUMERIC_STD# -- Loading package std_logic_arith# -- Loading package STD_LOGIC_UNSIGNED# -- Compiling entity uppgift_3b# -- Compiling architecture BLOCK_RAM_ROM_FPGA of uppgift_3b# # vcom -93 -work work {C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht}# Model Technology ModelSim ALTERA vcom 10.0d Compiler 2012.01 Jan 18 2012# -- Loading package STANDARD# -- Loading package TEXTIO# -- Loading package std_logic_1164# -- Compiling entity uppgift_3b_vhd_tst# -- Compiling architecture uppgift_3b_arch of uppgift_3b_vhd_tst# ** Warning: [4] C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(72): (vcom-1207) An abstract literal and an identifier must have a separator between them.# ** Warning: [4] C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(74): (vcom-1207) An abstract literal and an identifier must have a separator between them.# ** Warning: [4] C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(76): (vcom-1207) An abstract literal and an identifier must have a separator between them.# ** Warning: [4] C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(78): (vcom-1207) An abstract literal and an identifier must have a separator between them.# ** Error: C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(79): String literal found where non-array type ieee.std_logic_1164.STD_LOGIC was expected.# ** Error: C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(73): (vcom-1272) Length of expected is 3; length of actual is 2.# ** Error: C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(85): VHDL Compiler exiting# ** Error: c:/altera/12.0/modelsim_ase/win32aloem/vcom failed.# Error in macro ./uppgift_3b_run_msim_rtl_vhdl.do line 10# c:/altera/12.0/modelsim_ase/win32aloem/vcom failed.# while executing# "vcom -93 -work work {C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht}"#
these ....?
--- Quote Start ---
--- Quote End ---
we_ram <= "1";
When you use double quotes, it declares a vector, even if you have one bit. So "1" is a 1-bit std_logic_vector, not a std_logic. Try using '1' instead, which will be a std_logic.
--- Quote Start ---
--- Quote End ---
addr_ram <= "01";
As the message says, addr_ram is a 3 bit vector and you are trying to feed it with a 2-bit value.
BEGIN
-- test protokoll case 1
WAIT FOR 100ns;
addr_ram <= "01";
-- test protokoll case 2
WAIT FOR 100ns;
addr_rom <= "10";
-- test protokoll case 3
WAIT FOR 100ns;
data_ram <= "011";
-- test protokoll case 4
WAIT FOR 100ns;
we_ram <= '1';
WAIT;
END PROCESS init;
i have this
# ** Error: C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(75): (vcom-1272) Length of expected is 3; length of actual is 2.# ** Error: C:/altera_trn/VHDL_kurs/uppgift_3b/simulation/modelsim/uppgift_3b.vht(97): VHDL Compiler exiting# ** Error: c:/altera/12.0/modelsim_ase/win32aloem/vcom failed.
I already gave you the reason for that error.
