16603 Discussions
the "R" ,"F" of the chip planner ?
https://www.alteraforum.com/forum/attachment.php?attachmentid=5023
can you tell me that
1 : what is the mean of the "r" ,'f', such as the R : 4.449ns, f:3.984ns,
2 :is the red Vertical line and the red level line global clk ??
3 : If I want to see the delay from cell to output pin ,how i do ?
thank you
Rise delay and Fall delay.
The red vertical lines I believe are because you clicked on Show Physical Routing, so it's trying to do that.
I do not use Chip Planner to explore timing directly. I pretty much always use TimeQuest to look at the timing, and then will select path/s from a report_timing command and right-click Locate to Chip Planner. The TimeQuest report breaks timing numbers out in a much more readable way, not only with better details but with the whole "big picture" of how the path is analyzed. The Chip Planner then allows me to see the X/Y hops and visualize what's going on.
