I have some problem with simulaion fpga project with twentynm_fp_mac_encypted component. How can I get HDL code for simulation of this component or find full information about functions of this componet ? Thank youLink Copied
I need to run simulation OpenCL FPGA project of neural network (NN) with float point computations.
Can I generate in Qsys tool HDL code of this NN for simulation ?- Mark as New
--- Quote Start --- QuestaSim get this error Module 'twentynm_fp_mac_encrypted' is not define. As per you previous threadhttps://www.alteraforum.com/forum/showthread.php?t=57404 --- Quote End --- Can you edit the msim_setuo.tcl file and check again. 1.Add below lines in Compile device library files section of msim_setuo.tcl
eval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_atoms_ncrypt.v" -work twentynm
eval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_hssi_atoms_ncrypt.v" -work twentynm_hssi
eval vlog $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/twentynm_hip_atoms_ncrypt.v" -work twentynm_hip
Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
--- Quote Start --- Hi, Can you edit the msim_setuo.tcl file and check again. 1.Add below lines in Compile device library files section of msim_setuo.tcl
Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- This is not working. Instantitaion of twentynm_fp_mac_encrypted failed. Design unit is not found
Hi ,
Can you share your msim_setuo.tcl file? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)- Mark as New
Hi ,
You can simulate designs using the encrypted IP but cannot edit them. To simulate the IP, you need to compile the twentyfivenm library. This file can be found in the Quartus intallation directory. C:\IntelFPG\17.1\quartus\eda\sim_lib You can compile the twnetyfivenm VHDL /Verilog files into your work library and then recompile and simulate your design.
Topic Options
