16606 Discussions
using typedef intput argument for function
Hi
I want to pass a signal with a defined typedef into a function, however I got this error:
10476: type identifier "data" does nto agree with its usage as "int_array" type.
10559: actual formal parameter "data" must be a signal
and I couldn't find an answer for it. My code is as followed.
-------------- Sub function --------------------- package function_list is --* typedef type int_array is array (integer range <>) of integer; --* functions function sum(signal data: int_array(0 to 9)) return integer; end function_list; package body function_list is function sum(signal data: int_array(0 to 9)) return integer is variable sum_val: integer range 0 to 255 :=0; begin for i in 0 to 9 loop sum_val:= sum_val + data(i); end loop; return sum_val; end sum; end function_list; --------------- Main file -------- library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; use work.function_list.all; architecture rtl of main is type int_array is array (integer range <>) of integer; signal data: int_array(0 to 9); begin sum_process: process(sum_flag,clk) variable sum_val: integer range 0 to 255; begin if rising_edge(clk) then if sum_flag = '1' then sum_val:= sum(data); end if; end if; end process; end rtl;
This is because of the strong typing in VHDL.
The int_array type in the function_list package is not the same type as the one you declared in the "main" entity.
Hence the missmatch when you call the sum function, as data is int_array, while the function wants work.function_list.int_array
The fix here is to remove the type declaration from the main file. You dont need it as it is already declared in the included function_list package.
note: VHDL 2008 includes the integer_vector type that is an array of integers.
Thanks Tricky.
It get it now. Just one more question regarding to "integer_vector":
- How to use / which package do I have to include so that I can use this "integer_vector" type ? Since it gives no suggestion for this type when I'm typing. I tried to search for answer but couldn't find.
First of all, integer_vector requires that you use VHDL 2008. Quartus does not have full 2008 support unless you use Quartus Pro 17+, so it may not be supported.
integer_vector is part of the std.standard package that is included in all VHDL files by default, so no package inclusion is necessary.
