uvm
sn00011
I'm doing SPI using uvm project in questasim..in that project rtl file,tb,uvm components files their.. How to execute this files...
Vicky1
Hi sree, For simplicity keep all files in one directory. For SPI environment execution using Questasim follow the sequence as below, From the command prompt navigate to SPI environment directory & then use below command, qverilog SPI.v (DUT) package.sv(package file) interface.sv(interface file) top.sv(top level module file) e.g. qverilog spi.v pkg.sv spi_if.sv spi_top.sv Regards, Vikas
