vhdl error
nadav12_batito
i neep to plan counter bcd
library ieee;
use ieee.std_logic_1164.all;
entity h145 is
port (
resetn: in std_logic;
clk: in std_logic;
sclear: in std_logic;
cep, cet: in std_logic;
qout: buffer integer range 0 to 7
end entity h145;
architecture are_h145 of h145 is
signal r: std_logic;
begin
process (clk)
begin
r <= cep and cet;
if resetn = '0' then
qout <= 0;
elsif resetn = '1' and sclear = '1' then
qout <=0;
elsif resetn = '1' and sclear = '1' and r = '1' then
qout <= qout+1 ;
else
qout <= qout;
end if;
end process;
end architecture are_h145;
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity h145_tb is
end h145_tb;
architecture are_h145_tb of h145_tb is
component h145
port( resetn: in std_logic;
clk: in std_logic;
end component;
signal resetn, clk,sclear,cet,cep: STD_LOGIC;
signal qout:integer range 0 to 7;
signal r:std_logic;
begin
gen_inst: h145 port map(resetn, clk,sclear,cep,cet ,qout);
process
begin
r <= cep and cet;
resetn <= '0';
wait for 10 ns;
assert qout = 0
report "Test Case 1 Failed"
severity error;
sclear<= '1'; resetn<= '1';
wait for 10 ns;
assert qout = 0
severity error;
sclear<= '0'; resetn<= '1';r<='1';
wait for 10 ns;
assert qout =qout+1;
severity error;
sclear<= '0'; resetn<= '1';r<='0';
wait for 10 ns;
assert qout =qout
severity error;
assert false
report "End of test"
severity note;
wait;
end process;
end are_h145_tb;
i accept the following errorError (10533): VHDL Wait Statement error at h145.vhd(52): Wait Statement must contain condition clause with UNTIL keyword
Error (12153): Can't elaborate top-level user hierarchy
what the probelm in dis program?
roeekalinsky
Valued Contributor I
Looks like you're trying to synthesize your test bench, which makes no sense.  Are you trying to synthesize or simulate?  The test bench is for simulation only.  Whereas for synthesis the top level should be entity h145 without the test bench.
roeekalinsky
nadav12_batito
i want to write test bench for  pogram h145
RichardTanSY_Intel
Quartus software is not a simulator tool so you should Not compile testbench using it. Use the Questa Intel FPGA edition software or other third party simulator to compile the testbench.
Quartus is primarily used for synthesizing, fitting, and generating programming files (like bitstreams) for FPGA devices.
library ieee;
entity h145 is
port (
clk: in std_logic;
end entity h145;
begin
process (clk)
begin
r <= cep and cet;
qout <= 0;
qout <=0;
qout <= qout+1 ;
else
qout <= qout;
end if;
end process;
As what @roeekalinsky mentioned, the code above (entity h145) is synthesizable. The testbench code (entity h145_tb) is not synthesizable and should Not be compiled using Quartus.
Questa Intel FPGA Edition Simulation Flow Reference:
Lite/Standard Edition:
https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
 Pro Edition:
https://www.intel.com/content/www/us/en/docs/programmable/691278/current.html
Richard Tan
RichardTanSY_Intel
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
RichardTanSY_Intel
Thank you for acknowledging the solution provided. I'm pleased to know that your question has been addressed.
Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Thank you and have a great day!
Richard Tan
