17254 Discussions
when i create simulation model,Error: An unexpected error occurred during Generate: java lang.Error:
ishikawa
when i create simulation model,Error: An unexpected error occurred during Generate: java.lang.Error: Call to quartus_sh failed unexpectedly: CreateProcess failed: No such file or directory
i++ debug log file
This file contains diagnostic information. Any errors
or unexpected behavior encountered when running i++
should be reported as bugs. Thank you.
Compiler Command: i++ -march=CycloneV counter.cpp -o test-fpga.exe
2020.10.15.14:47:24 Info: Doing: <b>qsys-script --script=count.tcl</b>
2020.10.15.14:47:27 Info: create_system count
2020.10.15.14:47:28 Info: set_project_property HIDE_FROM_IP_CATALOG false
2020.10.15.14:47:28 Info: set_project_property DEVICE_FAMILY Cyclone V
2020.10.15.14:47:28 Info: set_project_property DEVICE 5CEFA9F23I7
2020.10.15.14:47:28 Info: add_instance count_internal_inst count_internal
2020.10.15.14:47:28 Info: set_instance_property count_internal_inst AUTO_EXPORT true
2020.10.15.14:47:28 Info: save_system count.qsys
Generating qsys simulation system: tb
ys-script --1 --search-path=C:/intelFPGA_lite/17.1/hls/ip/,.,../components/**/*,$ --script=C:/intelFPGA_lite/17.1/hls/share/lib/tcl/hls_sim_generate_qsys.tcl --cmd=set quartus_pro 0; set num_reset_cycles 4; set sim_qsys tb; set component_list count; set component_call_count_filename .</b>
2020.10.15.14:47:33 Info: create_system tb
2020.10.15.14:47:33 Info: add_instance clock_reset_inst hls_sim_clock_reset
2020.10.15.14:47:33 Info: set_instance_parameter_value clock_reset_inst RESET_CYCLE_HOLD 4
2020.10.15.14:47:33 Info: add_instance count_inst count
2020.10.15.14:47:34 Info: get_composed_instance_assignment count_inst count_internal_inst hls.cosim.name
2020.10.15.14:47:34 Info: add_instance main_dpi_controller_inst hls_sim_main_dpi_controller
2020.10.15.14:47:34 Info: set_instance_parameter_value main_dpi_controller_inst NUM_COMPONENTS 1
2020.10.15.14:47:34 Info: set_instance_parameter_value main_dpi_controller_inst COMPONENT_NAMES_STR count
2020.10.15.14:47:34 Info: set_instance_parameter_value main_dpi_controller_inst SIM_COMPONENT_CALL_COUNT_LOG_FILE .
2020.10.15.14:47:34 Info: add_connection clock_reset_inst.clock main_dpi_controller_inst.clock
2020.10.15.14:47:34 Info: add_connection clock_reset_inst.clock2x main_dpi_controller_inst.clock2x
2020.10.15.14:47:34 Info: add_connection clock_reset_inst.reset main_dpi_controller_inst.reset
2020.10.15.14:47:34 Info: add_connection main_dpi_controller_inst.reset_ctrl clock_reset_inst.reset_ctrl
2020.10.15.14:47:34 Info: add_connection clock_reset_inst.clock count_inst.clock
2020.10.15.14:47:34 Info: add_connection clock_reset_inst.reset count_inst.reset
2020.10.15.14:47:34 Info: get_instance_interfaces count_inst
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst call DESCRIPTION
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst call CLASS_NAME
2020.10.15.14:47:34 Info: get_instance_interface_ports count_inst call
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst clock DESCRIPTION
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst clock CLASS_NAME
2020.10.15.14:47:34 Info: get_instance_interface_ports count_inst clock
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst reset DESCRIPTION
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst reset CLASS_NAME
2020.10.15.14:47:34 Info: get_instance_interface_ports count_inst reset
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst return DESCRIPTION
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst return CLASS_NAME
2020.10.15.14:47:34 Info: get_instance_interface_ports count_inst return
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst returndata DESCRIPTION
2020.10.15.14:47:34 Info: get_instance_interface_property count_inst returndata CLASS_NAME
2020.10.15.14:47:34 Info: get_instance_interface_ports count_inst returndata
2020.10.15.14:47:34 Info: add_instance component_dpi_controller_count_inst hls_sim_component_dpi_controller
2020.10.15.14:47:34 Info: add_connection clock_reset_inst.clock component_dpi_controller_count_inst.clock
2020.10.15.14:47:34 Info: add_connection clock_reset_inst.clock2x component_dpi_controller_count_inst.clock2x
2020.10.15.14:47:34 Info: add_connection clock_reset_inst.reset component_dpi_controller_count_inst.reset
2020.10.15.14:47:34 Info: add_connection component_dpi_controller_count_inst.component_call count_inst.call
2020.10.15.14:47:34 Info: add_connection count_inst.return component_dpi_controller_count_inst.component_return
2020.10.15.14:47:34 Info: get_instance_interface_port_property count_inst returndata returndata WIDTH
2020.10.15.14:47:34 Info: set_instance_parameter_value component_dpi_controller_count_inst RETURN_DATAWIDTH 32
2020.10.15.14:47:34 Info: add_connection count_inst.returndata component_dpi_controller_count_inst.returndata
2020.10.15.14:47:34 Info: set_instance_parameter_value component_dpi_controller_count_inst COMPONENT_NAME count
2020.10.15.14:47:34 Info: add_instance count_component_dpi_controller_bind_conduit_fanout_inst avalon_conduit_fanout
2020.10.15.14:47:34 Info: set_instance_parameter_value count_component_dpi_controller_bind_conduit_fanout_inst numFanOut 0
2020.10.15.14:47:34 Info: add_instance count_component_dpi_controller_enable_conduit_fanout_inst avalon_conduit_fanout
2020.10.15.14:47:34 Info: set_instance_parameter_value count_component_dpi_controller_enable_conduit_fanout_inst numFanOut 0
2020.10.15.14:47:34 Info: add_connection component_dpi_controller_count_inst.dpi_control_bind count_component_dpi_controller_bind_conduit_fanout_inst.in_conduit
2020.10.15.14:47:34 Info: add_connection component_dpi_controller_count_inst.dpi_control_enable count_component_dpi_controller_enable_conduit_fanout_inst.in_conduit
2020.10.15.14:47:34 Info: add_instance split_component_start_inst avalon_split_multibit_conduit
2020.10.15.14:47:34 Info: set_instance_parameter_value split_component_start_inst multibit_width 1
2020.10.15.14:47:34 Info: add_connection main_dpi_controller_inst.component_enabled split_component_start_inst.in_conduit
2020.10.15.14:47:34 Info: add_connection split_component_start_inst.out_conduit_0 component_dpi_controller_count_inst.component_enabled
2020.10.15.14:47:34 Info: add_instance concatenate_component_done_inst avalon_concatenate_singlebit_conduits
2020.10.15.14:47:34 Info: set_instance_parameter_value concatenate_component_done_inst multibit_width 1
2020.10.15.14:47:34 Info: add_connection concatenate_component_done_inst.out_conduit main_dpi_controller_inst.component_done
2020.10.15.14:47:34 Info: add_instance concatenate_component_wait_for_stream_writes_inst avalon_concatenate_singlebit_conduits
2020.10.15.14:47:34 Info: set_instance_parameter_value concatenate_component_wait_for_stream_writes_inst multibit_width 1
2020.10.15.14:47:34 Info: add_connection concatenate_component_wait_for_stream_writes_inst.out_conduit main_dpi_controller_inst.component_wait_for_stream_writes
2020.10.15.14:47:34 Info: add_connection component_dpi_controller_count_inst.component_done concatenate_component_done_inst.in_conduit_0
2020.10.15.14:47:34 Info: add_connection component_dpi_controller_count_inst.component_wait_for_stream_writes concatenate_component_wait_for_stream_writes_inst.in_conduit_0
2020.10.15.14:47:34 Info: save_system tb.qsys
2020.10.15.14:47:39 Info: Saving generation log to D:/count222/test-fpga.prj/verification/tb/tb_generation.rpt
2020.10.15.14:47:39 Info: Starting: <b>Create simulation model</b>
2020.10.15.14:47:39 Info: qsys-generate D:\count222\test-fpga.prj\verification\tb.qsys --simulation=VERILOG --allow-mixed-language-simulation --output-directory=D:\count222\test-fpga.prj\verification\tb\simulation --family="Cyclone V" --part=5CEFA9F23I7
2020.10.15.14:47:39 Info: Loading verification/tb.qsys
2020.10.15.14:47:39 Info: Reading input file
2020.10.15.14:47:39 Info: Adding clock_reset_inst [hls_sim_clock_reset 1.0]
2020.10.15.14:47:39 Info: Parameterizing module clock_reset_inst
2020.10.15.14:47:39 Info: Adding component_dpi_controller_count_inst [hls_sim_component_dpi_controller 1.0]
2020.10.15.14:47:39 Info: Parameterizing module component_dpi_controller_count_inst
2020.10.15.14:47:39 Info: Adding concatenate_component_done_inst [avalon_concatenate_singlebit_conduits 1.0]
2020.10.15.14:47:39 Info: Parameterizing module concatenate_component_done_inst
2020.10.15.14:47:39 Info: Adding concatenate_component_wait_for_stream_writes_inst [avalon_concatenate_singlebit_conduits 1.0]
2020.10.15.14:47:39 Info: Parameterizing module concatenate_component_wait_for_stream_writes_inst
2020.10.15.14:47:39 Info: Adding count_component_dpi_controller_bind_conduit_fanout_inst [avalon_conduit_fanout 1.0]
2020.10.15.14:47:39 Info: Parameterizing module count_component_dpi_controller_bind_conduit_fanout_inst
2020.10.15.14:47:39 Info: Adding count_component_dpi_controller_enable_conduit_fanout_inst [avalon_conduit_fanout 1.0]
2020.10.15.14:47:39 Info: Parameterizing module count_component_dpi_controller_enable_conduit_fanout_inst
2020.10.15.14:47:39 Info: Adding count_inst [count 1.0]
2020.10.15.14:47:40 Info: Parameterizing module count_inst
2020.10.15.14:47:40 Info: Adding main_dpi_controller_inst [hls_sim_main_dpi_controller 1.0]
2020.10.15.14:47:40 Info: Parameterizing module main_dpi_controller_inst
2020.10.15.14:47:40 Info: Adding split_component_start_inst [avalon_split_multibit_conduit 1.0]
2020.10.15.14:47:40 Info: Parameterizing module split_component_start_inst
2020.10.15.14:47:40 Info: Building connections
2020.10.15.14:47:40 Info: Parameterizing connections
2020.10.15.14:47:40 Info: Validating
2020.10.15.14:47:40 Info: Done reading input file
2020.10.15.14:47:40 Warning: tb.component_dpi_controller_count_inst.dpi_control_slaves_ready: Interface has no signals
2020.10.15.14:47:40 Warning: tb.component_dpi_controller_count_inst.dpi_control_slaves_done: Interface has no signals
2020.10.15.14:47:40 Warning: tb.component_dpi_controller_count_inst.dpi_control_stream_writes_active: Interface has no signals
2020.10.15.14:47:40 Warning: tb.component_dpi_controller_count_inst: <b>component_dpi_controller_count_inst.dpi_control_slaves_ready</b> must be exported, or connected to a matching conduit.
2020.10.15.14:47:40 Warning: tb.component_dpi_controller_count_inst: <b>component_dpi_controller_count_inst.dpi_control_slaves_done</b> must be exported, or connected to a matching conduit.
2020.10.15.14:47:40 Warning: tb.component_dpi_controller_count_inst: <b>component_dpi_controller_count_inst.dpi_control_stream_writes_active</b> must be exported, or connected to a matching conduit.
2020.10.15.14:47:40 Warning: tb.component_dpi_controller_count_inst: <b>component_dpi_controller_count_inst.read_implicit_streams</b> must be exported, or connected to a matching conduit.
2020.10.15.14:47:40 Warning: tb.component_dpi_controller_count_inst: <b>component_dpi_controller_count_inst.readback_from_slaves</b> must be exported, or connected to a matching conduit.
2020.10.15.14:47:40 Info: tb: Generating <b>tb</b> "<b>tb</b>" for SIM_VERILOG
2020.10.15.14:47:41 Info: clock_reset_inst: "<b>tb</b>" instantiated <b>hls_sim_clock_reset</b> "<b>clock_reset_inst</b>"
2020.10.15.14:47:41 Info: component_dpi_controller_count_inst: "<b>tb</b>" instantiated <b>hls_sim_component_dpi_controller</b> "<b>component_dpi_controller_count_inst</b>"
2020.10.15.14:47:41 Info: concatenate_component_done_inst: "<b>tb</b>" instantiated <b>avalon_concatenate_singlebit_conduits</b> "<b>concatenate_component_done_inst</b>"
2020.10.15.14:47:41 Info: count_component_dpi_controller_bind_conduit_fanout_inst: "<b>tb</b>" instantiated <b>avalon_conduit_fanout</b> "<b>count_component_dpi_controller_bind_conduit_fanout_inst</b>"
2020.10.15.14:47:41 Info: count_inst: "<b>tb</b>" instantiated <b>count</b> "<b>count_inst</b>"
2020.10.15.14:47:41 Info: main_dpi_controller_inst: "<b>tb</b>" instantiated <b>hls_sim_main_dpi_controller</b> "<b>main_dpi_controller_inst</b>"
2020.10.15.14:47:41 Info: split_component_start_inst: "<b>tb</b>" instantiated <b>avalon_split_multibit_conduit</b> "<b>split_component_start_inst</b>"
2020.10.15.14:47:41 Info: irq_mapper: "<b>tb</b>" instantiated <b>altera_irq_mapper</b> "<b>irq_mapper</b>"
2020.10.15.14:47:41 Info: count_internal_inst: "<b>count_inst</b>" instantiated <b>count_internal</b> "<b>count_internal_inst</b>"
2020.10.15.14:47:41 Info: tb: Done "<b>tb</b>" with 10 modules, 70 files
2020.10.15.14:47:41 Info: qsys-generate succeeded.
2020.10.15.14:47:41 Info: Finished: <b>Create simulation model</b>
2020.10.15.14:47:41 Info: Starting: <b>Create Modelsim Project.</b>
2020.10.15.14:47:41 Info: sim-script-gen --spd=D:\count222\test-fpga.prj\verification\tb\tb.spd --output-directory=D:/count222/test-fpga.prj/verification/tb/simulation/ --use-relative-paths=true
2020.10.15.14:47:41 Info: Doing: <b>ip-make-simscript --spd=D:\count222\test-fpga.prj\verification\tb\tb.spd --output-directory=D:/count222/test-fpga.prj/verification/tb/simulation/ --use-relative-paths=true</b>
Exception in thread "main" java.lang.Error: Call to quartus_sh failed unexpectedly:
package "tb2" isn't loaded statically
while executing
"load "" tb2 "
ishikawa
I use Quartus prime lite17.1,Modelsim starter edition,intel HLS compiler.
I want to generate verilog from C++ using intel hls compiler.
EBERLAZARE_I_Intel
Are you using Windows or Linux?
You may need to check if your are navigated to the correct directory:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/archives/ug-hls-getting-started-19-3.pdf#page=17
You may refer to below document on the HLS compiler reference manual:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/mnl-hls-std-reference.pdf
ishikawa
 i use windows10.
We have already checked the sites provided. I'm following, but when I do test-fpga at the command prompt, I get an error like I described in the first paragraph.
I've attached the batch file I'm using. I would be very grateful if you can find a solution.
ihc_setup.bat
@echo off
::Please Set Following Param
::Set IHC root path
set IHCROOT=C:\intelFPGA_lite\17.1\hls
::Set VC install path
set VC_INSTALL=C:\Program Files (x86)\Microsoft Visual Studio 10.0
::Do not edit from here!!
::Set Tools Env
set VS100COMNTOOLS=%VC_INSTALL%\Common7\Tools
set PATH=%VC_INSTALL%\VC\bin\amd64;C:\IntelFPGA\17.1\modelsim_ase\win32aloem;%PATH%
set INCLUDE=C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1\Include;%VC_INSTALL%\VC\include;%INCLUDE%
set LIB=%VC_INSTALL%\VC\lib\amd64;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1\Lib\x64;%LIB%
set LIBPATH=%VC_INSTALL%\VC\lib\amd64;C:\Program Files (x86)\Microsoft SDKs\Windows\v7.1\Lib\x64;%LIBPATH%
call %IHCROOT%\init_hls.bat
cmd
build.bat
@echo off
set "SOURCE_FILES=counter.cpp"
set "HLS_CXX_FLAGS="
:: This batch file will compile the example design to three standard targets:
:: 1) test-msvc Compile the example design to the CPU
:: Uses Visual Studio 2010
:: 2) test-x86-64 Compile the example design to the CPU
:: Uses the Intel HLS Compiler
:: 3) test-fpga Synthesize the example design to HDL
:: Generates a cosimulation executable to simulate the HDL
:: 4) clean Remove any temporary files generated by the compiler
:: Usage: build.bat <target>
:: Example: build.bat test-x86-64
:: Only one argument expected
if not "%2"=="" goto usage
:: Accept the user's target, else default to x86-64
if not "%1"=="" (
set "TARGET=%1"
) else (
set "TARGET=test-x86-64"
echo No target specified, defaulting to %TARGET%
echo Available targets: test-x86-64, test-fpga, test-msvc, clean
:: Any tools installed with HLS can be found relative to the location of i++
for %%I in (i++.exe) do (
set "HLS_INSTALL_DIR=%%~dp$PATH:I"
set "HLS_INSTALL_DIR=%HLS_INSTALL_DIR%.."
:: Set up the compile variables
if "%TARGET%" == "test-x86-64" (
set "CXX=i++"
set "CXXFLAGS=%HLS_CXX_FLAGS% -march=x86-64"
set "LFLAGS=-o %TARGET%.exe"
) else if "%TARGET%" == "test-fpga" (
set "CXX=i++"
set "CXXFLAGS=%HLS_CXX_FLAGS% -march=CycloneV
) else if "%TARGET%" == "test-msvc" (
set "CXX=cl"
set "CXXFLAGS=/I ""%HLS_INSTALL_DIR%\include"" /nologo /EHsc /wd4068 /DWIN32 /MD"
set "LFLAGS=/link ""/libpath:%HLS_INSTALL_DIR%\host\windows64\lib"" hls_emul.lib /out:%TARGET%.exe"
) else if "%TARGET%" == "clean" (
del /S /F /Q test-msvc.exe test-fpga.exe test-fpga.prj test-x86-64.exe > NUL
rmdir /S /Q test-fpga.prj > NUL
goto:eof
) else (
goto usage
:: Replace "" with " in the flags
set "CXXFLAGS=%CXXFLAGS:""="%"
set "LFLAGS=%LFLAGS:""="%"
:: Kick off the compile
echo %CXX% %CXXFLAGS% %SOURCE_FILES% %LFLAGS%
if not ERRORLEVEL 0 (
echo Error: Compile failed
exit /b 1
echo Run %TARGET%.exe to execute the test.
:: We're done!
goto:eof
:: Dump the usage if we get unexpected input
:usage
echo Usage: build.bat [target]
echo Targets: test-msvc, test-x86-64, test-fpga, clean
echo Example: build.bat test-x86-64
exit /b 2
EBERLAZARE_I_Intel
Have you try using the version 19.3 and above to test?
ishikawa
I used 17.1 because I heard that there is no intelHLS compiler after 17.1.
I checked the manual and did a high-level synthesis, but I got the following error in the debug file.
2020.11.16.15:11:40 Info: Regenerate these scripts whenever you make any change to any Quartus-generated IP in your project.
2020.11.16.15:11:40 Info: Finished: <b>Create Modelsim Project.</b>
Error loading design
er\test-fpga.prj\verification>set rundir=c:\hlspractice\counter\test-fpga.prj\verification
c:\hlspractice\counter\test-fpga.prj\verification>set scripthome=c:\hlspractice\counter\test-fpga.prj\verification\
c:\hlspractice\counter\test-fpga.prj\verification>cd c:\hlspractice\counter\test-fpga.prj\verification\
c:\hlspractice\counter\test-fpga.prj\verification>vsim -batch -do "do tb/simulation/mentor/msim_compile.tcl"
Reading C:/altera/13.1/modelsim_ase/tcl/vsim/pref.tcl
Error: ** Error: (vish-3296) Unknown option '-batch'.
Error: Use the -help option for complete vsim usage.
c:\hlspractice\counter\test-fpga.prj\verification>set exitCode=1
c:\hlspractice\counter\test-fpga.prj\verification>exit /b 1
