Error (10500): VHDL syntax error at Transmit2.vhd(106) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at Transmit2.vhd(142) near text ";"; expecting ":=", or "<=" constant enableit : STD_LOGIC := '1'; constant disableit : STD_LOGIC := '0'; process(A) begin while (whilelooptrue = enableit) loop if SW(0) = '1' then H1:tether port map ( ff_tx_data => tx_data, ff_tx_clk => CLOCK_50, --: IN STD_LOGIC; read => disableit, --: IN STD_LOGIC; writedata => tx_data, --: IN STD_LOGIC_VECTOR (31 DOWNTO 0); write => enableit, --: IN STD_LOGIC; clk => CLOCK_50, --: IN STD_LOGIC; reset => disableit, --: IN STD_LOGIC; tx_clk => CLOCK_50, --: IN STD_LOGIC; set_10 => set_10_external, --: IN STD_LOGIC; set_1000 => set_100_external, --: IN STD_LOGIC; ff_tx_crc_fwd => enableit, --: IN STD_LOGIC; ff_tx_rdy => enableit, --: OUT STD_LOGIC; ena_10 => disableit, --: OUT STD_LOGIC; eth_mode => disableit, --0 = 10/100Mbps, 1 = 1000Mbps : OUT STD_LOGIC; ff_tx_a_full => enableit, --: OUT STD_LOGIC; ff_tx_a_empty => disableit, --: OUT STD_LOGIC; magic_wakeup => disableit --: OUT STD_LOGIC); ); end if; end loop; end process;Link Copied
A component can be only instantiated in concurrent code, not inside a process.
does it mean that i move H1:tether port map outside the process and at the same time assign a variable to write like this write => whetherenable, --: IN STD_LOGIC;
then in the process, set whetherenable to '1' when SW(0) = '1' else whetherenable to '0'- Mark as New
The component instance can be linked to the process by signals, not variables. Variables are only defined inside a process.
At second sight, I noticed several violations of VHDL synatax/semantic rules - while constructs aren't supported for synthesizable VHDL - you can't connect multiple output ports to the same signal- Mark as New
excellent !!! i change to use signal instead of variable outside process , it is success to pass syntax checking.
