Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
xilinx ise 10.1 problem
hi ..
i install xilinx 10.1 ise . after installing i run ise. as it open a message appear ,
"xilinx ise has stopped working"
Problem signature:
Problem Event Name: APPCRASH
Application Name: _pn.exe
Application Version: 1.0.0.1
Application Timestamp: 4786a9f0
Fault Module Name: msvcrt.dll
it closes the ISE ..
how to fix it.
i m using windows 7
i install ise twice bt same error..
plz help me how to fix this error..
regards
Highlighted
Re: xilinx ise 10.1 problem
It's very simple: stop using Xilinx, move to Altera and have no problems with ****ty software anymore!
i have altera too ..
i i have a code that uses UNISIM library .
it dosent complie on qurtus .
what to do ?
Highlighted
Simulation libraries are designed for simulation only. You can't use them for synthesis.
Highlighted
plus, the unisim library is meant for xilinx's primitives. you gotta find their equivalents' for altera, which means you gotta study the code 🙂
