Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
xml report
hi everyone!
my question is the following: do/can quartus II make synthesis and par timing reports in xml format? (if someone can answer this question regarding precision and synplify i'd be happy)
thanks in advance!
Tools -> Options -> Processing -> Automatically General HTML Format report files.
There is no automatic way to generate an XML file (although if you do an export database for backwards compatibility, it does generate an XML, but the schema is not documented).
It should be easy, however, for you to generate your own XML using the Tcl package. See:
http://quartushelp.altera.com/13.0/master.htm#mergedprojects/tafs/tafs/tcl_pkg_report_ver_2.1.htm?gs... tcl package
See "get_report_panel_data"
