Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
94 Discussions
Intel Quick Assist Adapter 8950-SCCP
Huang1
I have a Intel Quick Assist Adapter 8950-SCCP (dh895xcc).
I can not find it's driver in intel site.
Intel® QuickAssist Technology Driver for Linux* – HW Version 1.X
Intel® QuickAssist Adapter Family for Servers
Can anyone give me some hint? thanks.
Ronny_G_Intel
Hi Huang1,
If QAT install was performed with intel_iommu=on and ./configure targeting PF use only:
This particular configuration is not valid since PFs are not able to be used when IOMMU is enabled.
Please refer to the following website for cpa_sample_code details:
https://intel.github.io/quickassist/GSG/2.X/sampleapplications.html#performance-sample-code
Note: Before running cpa_sample_code make sure QAT is properly configured, refer to: https://intel.github.io/quickassist/GSG/2.X/installation.html
Ronny G
Ronny_G_Intel
Hi Huang1,
You may want to use the following driver: https://www.intel.com/content/www/us/en/download/19734/intel-quickassist-technology-driver-for-linux-hw-version-1-x.html
This driver should also work for DH8925, DH8926, DH8950 and DH8955.
There is more information available here: https://ark.intel.com/content/www/us/en/ark/products/codename/60172/products-formerly-coleto-creek.html please be aware that this product has been discontinued.
Ronny G
Huang1
Hi Ronny,
  Thanks your kindly support on QAT 8950.
I did this on ubuntu 2204, no error appears.
  1. ./configure --enable-icp-debug -enable-icp-log-syslog --enable-icp-dc-return-counters-on-error
  2. make && make install
  3. make samples && make samples-install
And list it
#lspci -s 0b:00.0 -v
0b:00.0 Co-processor: Intel Corporation DH895XCC Series QAT
Subsystem: Intel Corporation DH895XCC Series QAT
Flags: bus master, fast devsel, latency 0, IRQ 40, IOMMU group 26
Memory at ea100000 (64-bit, prefetchable) [size=512K]
Memory at fcb40000 (64-bit, non-prefetchable) [size=256K]
Memory at fcb00000 (64-bit, non-prefetchable) [size=256K]
Capabilities: [b0] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [60] MSI-X: Enable+ Count=33 Masked-
Capabilities: [6c] Power Management version 3
Capabilities: [74] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [138] Alternative Routing-ID Interpretation (ARI)
Capabilities: [140] Single Root I/O Virtualization (SR-IOV)
Kernel driver in use: dh895xcc
Kernel modules: qat_dh895xcc
#lsmod | grep qat
qat_dh895xcc 20480 0
intel_qat 389120 2 usdm_drv,qat_dh895xcc
uio 28672 1 intel_qat
#systemctl status qat_service.service
● qat_service.service - LSB: modprobe the QAT modules, which loads dependant modules, before calling the user space utility to pass configuration parameters
Loaded: loaded (/etc/init.d/qat_service; generated)
Active: active (exited) since Wed 2024-06-12 20:18:32 CST; 13h ago
Docs: man:systemd-sysv-generator(8)
Process: 52444 ExecStart=/etc/init.d/qat_service start (code=exited, status=0/SUCCESS)
CPU: 1.042s
6月 12 20:18:31 jinhua-x570 systemd[1]: Starting LSB: modprobe the QAT modules, which loads dependant modules, before calling the user space utility to pass configuration parameters...
6月 12 20:18:31 jinhua-x570 qat_service[52493]: Restarting all devices.
6月 12 20:18:31 jinhua-x570 qat_service[52493]: Processing /etc/dh895xcc_dev0.conf
6月 12 20:18:32 jinhua-x570 qat_service[52495]: Checking status of all devices.
6月 12 20:18:32 jinhua-x570 qat_service[52495]: There is 1 QAT acceleration device(s) in the system:
6月 12 20:18:32 jinhua-x570 qat_service[52495]: qat_dev0 - type: dh895xcc, inst_id: 0, node_id: 0, bsf: 0000:0b:00.0, #accel: 6 #engines: 12 state: up
6月 12 20:18:32 jinhua-x570 systemd[1]: Started LSB: modprobe the QAT modules, which loads dependant modules, before calling the user space utility to pass configuration parameters.
But, when I run the sample code, there is error.
#./build/cpa_sample_code
Latency computation Disabled
qaeOpenFd:163 Memory file handle is not initialized. Initializing it now
qaeMemInit started
[error] SalCtrl_AdfServicesStartedCheck() - : Sal Ctrl failed to start in given time
[error] do_userStart() - : Failed to start services
/opt/qat/QAT.L.4.25.0-00001/quickassist/lookaside/access_layer/src/sample_code/performance/cpa_sample_code_main.c, main():486 Could not start sal for user space
Could you give me more advice on this? thank you.
Ronny_G_Intel
Hi Huang1,
Are you enabling sriov? I dont think you are, you are using: ./configure --enable-icp-debug -enable-icp-log-syslog --enable-icp-dc-return-counters-on-error
This error usually happends when QAT install was performed with intel_iommu=on and ./configure --enable-icp-sriov=host – verify vfs are running:
To start vfs enter: # service qat_service_vfs start
To verify vfs are running enter: # service qat_service_vfs status
Ronny G
Huang1
Hi Ronny G,
I did not enable sriov and set intel_iommu=on in ./configure step.
Actually I want to invest compression things on QAT 8950.
Could you help me on configure it correctly?  Thank you.
Ronny_G_Intel
Hi Huang1,
Ronny G
Huang1
Hi Ronny_G,
Thanks your kindly help.
I performance the test on a Intel CPU (Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz) (previously on a AMD).
Configured as:
./configure --enable-icp-debug --enable-icp-dc-return-counters-on-error --enable-icp-dc-only
The samples_code works:
Inst 0, Affin: 0, Dev: 0, Accel 0, EE 0, BDF 03:00:00
Inst 1, Affin: 1, Dev: 0, Accel 0, EE 0, BDF 03:00:00
API Data_Plane
Session State STATELESS
Algorithm DEFLATE
Huffman Type DYNAMIC
Mode ASYNCHRONOUS
Direction DECOMPRESS
Packet Size 8192
Compression Level 2
Corpus CALGARY_CORPUS
Corpus Filename calgary
CNV Recovery Enabled YES
Number of threads 2
Total Responses 79200
Total Retries 53921
Clock Cycles Start 578758886892702
Clock Cycles End 578760025055418
Total Cycles 1138162716
CPU Frequency(kHz) 3696230
Throughput(Mbps) 16907
Compression Ratio 0.4112
Sample code completed successfully.
Thank you very much on QAT env setup.
I will invest on compression test.
This ticket can be closed. I will raise new if having problem on compression test.
