Intel® QuickAssist Technology (Intel® QAT)
For questions and discussions related to Intel® QuickAssist Technology (Intel® QAT).
95 Discussions
Lewisburg Refresh C629A + Xeon D-1527, D-1528, D-1537, and D-1559 processors
jungsoolim
We are currently using Intel Xeon D-1527, D-1528, D-1537, and D-1559 processors.
We are planning to develop a PCIe card using the Lewisburg Refresh C629A chipset to utilize QAT (QuickAssist Technology).
We would like to ask if there could be any issues with card recognition or QAT functionality when this C629A-based PCIe card is connected as an endpoint to the CPUs mentioned above.
For reference, we are currently using the QAT8960 (based on the Lewisburg C628 chipset) without any issues — the card is recognized properly, and QAT works as expected.
Our main concern is whether there could be any compatibility issues between the older Xeon D processors we are using and the newer Lewisburg Refresh chipset.
Ronny_G_Intel
Hi jungsoolim,
I just got confirmation that the 629A device was never validated as an accelerator plug in.
It was qualified to be used as a QAT+PCH device only.
It is completely compatible with C629 in all other aspects.
I hope this answers your question.
Ronny G
Ronny_G_Intel
Hi jungsoolim,
Thank for reaching out to Intel Communities.
I am double-checking on this question and I will get back to you as soon as possible.
On the other hand, can you confirm that you have Intel Xeon D-1527, D-1528, D-1537, and D-1559 processors running with QAT8960?
Ronny G
jungsoolim
Hi Ronny,
Thank you for your response.
Yes, we are using the QAT8960 PCIe card (C628) together with the Intel Xeon D-1527, D-1528, D-1537, and D-1559 processors.
Please let us know if any additional information is needed.
Jungsoo Lim
Ronny_G_Intel
Hi jungsoolim,
Ronny G
jungsoolim
Hi Ronny,
Thank you for the clarification regarding the 629A device.
If the C629A has not been validated as an accelerator plug-in, it would be difficult for us to use it in our case.
We are therefore considering using the C627A instead.
Could you please confirm if the C627A has been validated as an accelerator plug-in?
Our plan is to develop a PCIe card based on the C627A to replace the QAT8960 PCIe card.
Thank you again for your support, and I look forward to your response.
Jungsoolim
Ronny_G_Intel
Hi Jungsoolim.
Unfortunately, none of the updated “A” or “R” SKUs for ICX are supported as a standalone plug in accelerator.
Ronny G
jungsoolim
Hi Ronny,
Thank you for the update.
As a reference, the Whitley PDG document also mentions that LGB-R SKUs are not supported with EPO as standalone plug-in accelerators.
In non-EPO mode, there are 3 available SKUs to be used: C621A, C627A, and C629A.
Commonly known as LBG-R. With regards to EPO mode, only the original LBG SKUs can be used (C625, C626, C627, C628, C629).
This is due to the decision not having an EPO version of SPS FW for C621A/C627A/C629A.
Jungsoo
Ronny_G_Intel
Hi jungsoolim,
I will be closing the internal ticket I opened for this issue, as I believe it has been resolved.
The community post will remain accessible, but I will no longer be monitoring it for updates.
If you have any further concerns or questions, please feel free to start a new community post.
Ronny G
